newageanubis
- 15
(This is a bonus question for a lab I have coming up next week.)
In this part of the lab, a large field coil is hooked up to a function generator that outputs a 100 kHz, 10V peak-to-peak waveform. A smaller test coil is connected to an oscilloscope and slowly inserted into the field coil. The induced emf can be read off of the oscilloscope. Knowing the number of turns and cross-sectional area of the test coil, calculate the magnetic field B inside the large test coil.
ε = -L*(dI/dt)
B = μNI/L
Solution 1:
I'm thinking that the emf in the test coil can be read off of the oscilloscope and represented as a sinusoidal function. The inductance of the test coil can be determined from its known geometric properties. Then, you rearrange the equation so that it reads:
-ε/L dt = dI
And integrate, taking I = 0 at t = 0 as the initial value. Then, since B = μNI/L, the magnetic field inside the field coil can be found as a function of time. You solve for the time of interest (time at which you want to know the B field) using the ε function and a specific ε value at the time of interest, and then solve for the B field using the previously determined function.
The only problem (other than the fact that I'm probably wrong) is that this solution requires me to have access to the dimensions of the field coil, which I don't know if I will.
Thanks in advance for your time.
