Calculating the mass and price of LPG needed to heat water
In summary: There has been a recent change in the conversion formula so the current value is 4.18kg*70*150 = 43,890kJ.
PraAnan
77
Hello everyone,
How many kilograms of lpg will you use if you heat 5 litres of water from 20C to 90C everyday for 30 days and how much will that cost if a 12.5kg cylinder is 1750 Rupees
The attempt at a solution
To heat 1 liter of water by 1C requires 4.18kJ so you then multiply this by 70 (the temperature difference) and then by 150 (the total amount of water) which gives 43,890kJ.
A kg of lpg =49,000kJ
So at 100% efficiency you will need 0.9kg of gas.
This is the part I'm not sure about, the efficiency of gas stoves.
I read that a typical stove is 50-60% efficient so at 50% efficiency you would need 1.8kg of gas which at a price of 140 Rupees per kg will come to 252 Rupees.
Is this correct or am I missing something obvious?
Thanks for reading
If there is no efficiency given anywhere I would assume 100% and comment that this too optimistic.
Likes CWatters
Thanks for the reply.
There is nothing mentioned about efficiency but I did write it because a part of the question which I didn't write as I thought it wasn't that important at the time (I translated it from our local language) actually says: if you heat 5 litres of water from 20C to 90C everyday using a gas cooker for 30 days.
I won't lose anything by writing the 100% value as well as the value after efficiency has been taken into account.
Apart from that though, I take it that the rest of my work was correct? and is the 50% number actually accurate? (I have since come across a post about a person testing the time it takes to boil water with an induction and gas cooker and they worked out that the efficiency of the gas cooker was 32%)
Looks ok to me.
When you burn LPG the main products are CO2 and water vapour both of which are hot. The efficiency of a pan of water on a gas stove is poor because these products escapes around the sides of the pan into the air without giving up much heat to the pan.
Some types of home heating system are much more efficient. In the UK most new gas water heaters have a condenser which recovers the latent heat from the water vapour. These can achieve efficiencies of over 90%.
If you use an electric heater with the element immersed in the water almost of the heat goes into the water and the efficiency can be close to 100% (if you ignore losses through the walls of the container).
Thanks for the help. : )
PraAnan said:
Hello everyone,
Thanks for reading
What is 150 (total amount of water )? Isnt the formulae is m*Change in temperature*specific heat req? How come is the mass of 1 liter is converted into 150 ??
5 liters per day for 30 days, i.e. 150 liters in total.
This thread is from 2019 by the way.
Related to Calculating the mass and price of LPG needed to heat water
1. How do I calculate the mass of LPG needed to heat water?
To calculate the mass of LPG needed to heat water, you will need to know the specific heat capacity of LPG, the mass of water, and the desired temperature change. The formula for calculating the mass of LPG is mass = (specific heat capacity of LPG x mass of water x temperature change) / (specific heat capacity of water x temperature change).
2. What is the specific heat capacity of LPG?
The specific heat capacity of LPG (liquefied petroleum gas) varies depending on the type of LPG and its composition. On average, the specific heat capacity of LPG is around 2.2 kJ/g·K.
3. How do I convert the mass of LPG to its price?
To convert the mass of LPG to its price, you will need to know the price per unit mass of LPG. This can vary depending on location and supplier. Once you have the price per unit mass, you can simply multiply it by the mass of LPG needed to heat the water.
4. How do I know how much LPG I need to heat a certain amount of water?
The amount of LPG needed to heat water depends on the specific heat capacity of LPG, the mass of water, and the desired temperature change. You can use the formula mentioned in the first question to calculate the mass of LPG needed.
5. Can I use a different type of gas instead of LPG to heat water?
Yes, you can use other types of gas such as natural gas or propane to heat water. However, the specific heat capacity and price per unit mass may vary, so you will need to adjust your calculations accordingly.
10K
