Calculating the pH of a Buffer Solution
  • Thread starter DapperDan
  • Tags
    Buffer Ph
In summary, the multi-step problem asks for the concentrations of two molecules, propanoic acid and sodium propanoate, when a third molecule, propanoic acid ion, is formed. The first two steps are completed, and the third step is stuck. The easy solution for part 3 is to use the Henderson-Hasselbalch equation to calculate the concentrations of the two molecules after the propanoic acid ion has been formed. The difficult solution for part 3 is to determine what the chemical equation would be for the reaction between propanoic acid ion and the propanoic acid solution.
DapperDan
(1) You are supplied with propanoic acid, CH3CH2CO2H, which has a pKa of 4.87 and density of 0.992 g/mL. If you take 8.62 mL of propanoic acid and make an aqueous solution with a total volume of 1450.0mL, what is the molarity of the solution?
(2) What is the pH of the propanoic acid solution?
(3) If 9.6 grams of sodium propanoate is added to 1.00L of the propanoic acid solution made in (1), what is the new pH for the buffer solution?
(4) If 0.01M of HCl(g) is bubbled into the buffer solution in (3), what is the change in pH assuming that there is no volume change?
(5) If 0.40g of NaOH(s) is dissolved in the buffer solution in (3), what is the change in pH assuming that there is no volume change?
Ka=[H+][A-]/[HA]
pH = -log[H+]
Others?
Hi everyone. I'm doing the multi-step problem above, and I've found myself stuck at part 3.
For step 1, I determined that the equation that we're dealing with is:
$$CH_3CH_2CO_2H + H_2O ⇔ CH_3CH_2CO_2^- + H_3O^+$$
I've also determined that the molar mass of propanoic acid is about 74.08g/mol, and we therefore have 0.11543 mol of propanoic acid. So we have $$\frac{0.11543 mol}{1.45L} = 0.07961 M$$
For part (2) I first found Ka. We are given pKa as 4.87. pKa = -log(Ka) so $$-log(K_a)=4.87$$
$$log(K_a)=-4.87$$
$$K_a=10^{-4.87}$$
$$K_a=1.349*10^{-5}$$
Based on the equation I determined in the previous step, we know that $$K_a=\frac{[CH_3CH_2CO_2^-][H_3O^+]}{[CH_3CH_2CO_2H]}$$
Using an ICE table I determined that $$1.349*10^{-5}=\frac{[x][x]}{[0.07961-x]}$$.
When solved for x, this produces x=0.00103, which corresponds to the concentrations of H30+ and CH3CH2CO2-. As pH is equal to -log[H+], we get pH=-log(0.00103), which gives pH=2.987.
For part 3, however, I am completely stumped. I cannot begin to even understand what our chemical equation would look like for the reaction involved sodium propanoate with the propanoic acid solution. I found the forumla for sodium propanoate, Na(C2H5COO), so I have $$CH_3CH_2CO_2^-+H_3O^+ +Na(C_2H_5COO) ⇔ ?$$
But I don't know how to complete this equation. How do these compounds interact? How can I write the equation for this interaction so I can start on this part of the problem? Please help, many thanks in advance for any assistance that can be provided.
Hard way: salt is dissociated, you can use ICE table with known initial concentration of propanoate anion.
Easy way: use Henderson-Hasselbalch equation. Technically it is just a rearrangement of the dissociation constant, but it is very useful for buffer problems.
http://www.chembuddy.com/?left=buffers&right=toc
Likes DapperDan
Thank you, I'm always down to use easy solutions!
For point of reference though, what would the dissociation of the salt look like? How would that be written in this case?
Also I have made more progress on the problem I think, if anyone is willing to take a look at my work:
In part (3) we are given 9.6 grams of Na(C2H5COO) which amounts to 0.0999349382 or roughly 0.1 moles. In one liter of solution we get 0.1M. Then using the Henderson-Hasselbalch equation:
$$pH=pK_a + log(\frac{[A-]}{[HA]})$$
$$pH=4.87+log(\frac{[0.1]}{[0.07961]})$$
$$pH=4.87+0.099032376$$
$$pH=4.97$$
For part (4) we are given 0.01M HCl which would give us 0.01M Cl-, our conjugate base. So then:
$$pH = pK_a+log(\frac{[A-]}{[HA]})$$
$$pH=4.87+log(\frac{[0.01]}{[0.07961]})$$
$$pH=4.87-0.9009676239$$
$$pH=3.97$$
Does this look correct?
Doesn't sound correct to me - what is the acid, what is the conjugate base in this buffer?
What is happening is that H+ from HCl protonates the propanoate anion, removing the conjugate base. You can assume protonation went to completion (it is not exact, but close enough).
Miraculously, your result looks OK.
Likes DapperDan and jim mcnamara
For part 4 Protonation has just decreased [A-] by 0.01 relative to part 3, and increased [HA] by the same amount. So I think you have to re-calculate numerator and denominator in the HH equation.
Part 5 should not be difficult, I think it is practically just returning to a previous situation.
Slightly off-topic: The example bears a horrid resemblance to the bizarre buffer we had to use to adjust a smorgasbord HPLC mobile phase for a {redacted} pharmaceutical cogener / impurity analysis.
IIRC, despite our 'good practice', it progressively contaminated pH electrodes, took up atmospheric CO2 fast enough to be scary, and grew 'bugs' quicker than an exposed agar plate...
YMMV.
For part 4 I get the ΔpH to be close to -0.1 following the indications I gave of how to calculate it.
More important than an answer being right or wrong, is to realize whether it is reasonable or not according to rough reasoning.
The solution has a pH near its pKa. To bring the pH down by one unit, as claimed, you would have to protonate of the order of 90% of the proprionate ions present which are 0.1 M, and there has been added only a 10th of their amount of acid.
More than a week has passed since the last post so sadly it looks the OP will have to go into my black book, see my sig.
FAQ: Calculating the pH of a Buffer Solution
What is a buffer solution?
A buffer solution is a solution that resists changes in pH when small amounts of acid or base are added. It is made up of a weak acid and its conjugate base, or a weak base and its conjugate acid.
How do you calculate the pH of a buffer solution?
The pH of a buffer solution can be calculated using the Henderson-Hasselbalch equation, which is pH = pKa + log([conjugate base]/[weak acid]). The pKa is the acid dissociation constant, and the concentrations of the conjugate base and weak acid can be determined from the initial concentrations and the buffer's equilibrium constant.
What is the importance of calculating the pH of a buffer solution?
Calculating the pH of a buffer solution is important because it allows us to determine the effectiveness of the buffer in resisting changes in pH. It also helps us understand how the buffer will respond to additions of acid or base, which is important in various biological and chemical processes.
What factors can affect the pH of a buffer solution?
The pH of a buffer solution can be affected by changes in the concentrations of the weak acid and conjugate base, as well as changes in temperature. Additionally, the addition of strong acid or base can also change the pH of a buffer solution.
How can you prepare a buffer solution with a specific pH?
To prepare a buffer solution with a specific pH, you can use the Henderson-Hasselbalch equation to determine the ratio of weak acid to conjugate base needed. Then, you can mix the appropriate amounts of the weak acid and conjugate base in a solution to achieve the desired pH.
