MHB Calculating the Probability of Faulty Plumbing in Hotel Rooms: A Case Study
The discussion centers on calculating the probability of clients being assigned rooms with faulty plumbing across three motels. It is established that 20% of clients stay at the Ramada Inn, 50% at the Sheraton, and 30% at the Lakeview Motor Lodge, with respective faulty plumbing rates of 5%, 4%, and 8%. The probability that a client will be assigned a room with faulty plumbing is calculated to be 5.4%. Additionally, the probability that a client with faulty plumbing was assigned to the Lakeview Motor Lodge is determined to be 44.4%. The calculations involve applying the law of total probability and conditional probability.
Roohul Amin
Dear all Please help in solving the following problem.
A large industrial firm uses 3 local motels to provide overnight accommodations for its clients. from past experience, it is known that 20% of the clients are assigned rooms at the Ramada Inn, 50% at the sheeraton and 30% at the Lakeview Motor Lodge. if the plumbing is faulty in 5% of the rooms at the Ramada Inn, in 4% of the rooms at the Sheraton and in 8% of the rooms at the Lakeview Motor Lodge, what the probability that
a) A client will be assigned a room with faulty plumbing?
b) A person with a room having faulty plumbing was assigned accommodation at the Lakeview Motor Lodge?
I have come with the following solution.
Let L: a client is assigned accommodation at Lakeview Motor Lodge
R: a client is assigned accommodation at Ramada Inn
S: a client is assigned accommodation at Sheraton
P(Lf): Probability of faulty plumbing rooms in Lakeview=0.08
P(Rf): Probability of faulty plumbing rooms in Ramada=0.05
P(Sf): Probability of faulty plumbing rooms in Sheraton=0.04
Now
a) P(client assigned with faulty plumbing room)=P(Lf/L)+P(Rf/R)+P(Sf/S)
=0.3*0.08+0.2*0.05+0.5*0.04
b) P(faulty plumbing room in Lakeview)=P(L/Lf)
=0.08*0.3
Needs help
Mathematics news on Phys.org
Now
=0.08*0.3
Needs help
Your answer for a) is 0.3*0.08+0.2*0.05+0.5*0.04 = 0.054, which is correct.
For b), you need to know what proportion of the clients with faulty plumbing were staying at Lakeview. In other words, you need to know $$\dfrac{\text{P(faulty plumbing room in Lakeview)}}{\text{P(client with faulty plumbing room)}} = \dfrac{0.024}{0.054}.$$
Imagine 1000 clients. 20%, 200, are assigned the Ramada Inn, 50%, 500, the Sheraton, and 30%, 300, the Motor Lodge.
Of the 200 assigned to the Ramada Inn, 5%, 10, have faulty plumbing. Of the 500 assigned to the Sheraton, 4%, 20, have faulty plumbing, and of the 300 assigned to the Motor Lodge, 8%, 24, have faulty plumbing. That is a total of 10+ 20+ 24= 54, out of 1000 who have faulty plumbing- 54/1000= 0.054 or 5.4% are assigned a room with faulty plumbing. Of those 54, 24 were assigned to the Motor Inn. Given that a person had faulty plumbing, the probability they were assigned to the Motor Inn is 24/54= 0.444 or 44.4%.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
