Calculating the Rate of Decrease in Diameter of a Melting Snowball
In summary, to find the rate of change of diameter when the diameter is 10 cm, we differentiate the volume formula for a sphere in terms of diameter, solve for the rate of change of diameter, and make the appropriate substitutions.
hatelove
101
A snowball melts in volume @ 1 cm³/min. At what rate is the diameter decreasing when the diameter is 10 cm?
Volume of a sphere: [tex]\frac{4}{3}\pi r^{3}[/tex]
Volume of a sphere in terms of diameter: [tex]\frac{\pi d^{3}}{6}[/tex]
Rate of volume: [tex]\frac{d}{d(time)}volume = -1 cm^{3}/min.[/tex]
Rate of diameter: [tex]\frac{d}{d(time)}10 cm = ?[/tex]
I'm not sure what to do at this point
I'll use \(s\) for the diameter, to avoid confusion with the derivatives. We have
\[V = \frac{\pi s^3}6.\]
Differentiate both sides with respect to time \(t\):
\[\Rightarrow\frac{dV}{dt} = \frac{\pi s^2}2\cdot\frac{ds}{dt}\]
Now solve for \(ds/dt\) and set \(s = 10\) an \(\frac{dV}{dt} = -1\).
How did you know to differentiate both sides?
I see we are trying to find [tex]\frac{ds}{dt}[/tex] but how did you know that differentiating both sides would result in [tex]\frac{ds}{dt}[/tex] appearing in the end?
Since \(V\) is a function of \(s\) and \(s\) is a function of time \(t\), the chain rule tells us that
\[\frac{dV}{dt} = \frac{dV}{ds}\cdot\frac{ds}{dt}.\]
This allows us to solve for \(\frac{ds}{dt}\) in terms of \(\frac{dV}{dt}\).
You can follow this same procedure in many other related rate problems: find a relationship between the variables, differentiate implicitly using the chain rule, solve for the unknown rate and make the appropriate substitutions.
FAQ: Calculating the Rate of Decrease in Diameter of a Melting Snowball
How do you calculate the rate of decrease in diameter of a melting snowball?
To calculate the rate of decrease in diameter of a melting snowball, you will need to measure the diameter of the snowball at different time intervals as it melts. Then, you can use the formula (d1-d2)/t to calculate the rate of decrease, where d1 is the initial diameter, d2 is the final diameter, and t is the time interval between the two measurements.
What units should be used when calculating the rate of decrease in diameter of a melting snowball?
The units used for the diameter measurements should be consistent, such as centimeters or inches. The units for time should also be consistent, such as seconds or minutes. The resulting rate of decrease will then be in units per time (e.g. cm/minute).
How does the rate of decrease in diameter of a melting snowball change over time?
The rate of decrease in diameter of a melting snowball will typically decrease over time as the snowball gets smaller. This is because the surface area of the snowball decreases as it melts, which results in a slower rate of melting.
Can the rate of decrease in diameter of a melting snowball be affected by external factors?
Yes, the rate of decrease in diameter of a melting snowball can be affected by factors such as temperature, humidity, wind, and the composition of the snowball. For example, a higher temperature will cause the snowball to melt faster, resulting in a higher rate of decrease in diameter.
How can the rate of decrease in diameter of a melting snowball be used in scientific research?
The rate of decrease in diameter of a melting snowball can be used in studies related to climate change, weather patterns, and material science. By understanding how different factors affect the melting rate of a snowball, scientists can gain insights into larger systems and phenomena.
