Calculating the roots of a quadratic with complex coefficien
In summary, the student attempted to find the roots of a quadratic equation, but found it to be too complicated. The student then tried to solve it using a complex number method, but it did not work. In the end, the student found the real and imaginary parts of the equation, and solved for x.
astrololo
200
Calculating the roots of a quadratic with complex coefficients
x^2 - (5i+14)x+2(5i+12)=0
I tried the quadratic solution but it gives too complicated solutions. I have no idea on how to do this...
You have something in the form of $$z^2=c$$ where $$c=a+bi$$ assume that a square root of c is y+zi, where $$(y+zi)^2=a+bi$$ Do you understand where to go from here? There are multiple methods to solve these problems, some easier than others.
Have you learned DeMoivre’s Theorem yet?
No, I didn't learn it.
The c^2=a+bi corresponds to what I had earlier, right ?
Okay.
Is the first part at least recognizable, do you know how to develop it into a formula for y and z?
No you just had c, you're looking for $$\sqrt(c)$$
Sorry, I was referring to this : z^2=18.75+25i
ISn't this good ?
where z=x-2.5i-7
ISn't this good ?
where z=x-2.5i-7
Looks okay.
You're looking for a $$(y+zi)^2=18.75+25i$$ equate the real and imaginary parts.
Likes SammyS
Student100 said:
First part looks okay, the second part isn't correct that's not the square root,
I don't understand. You want me to do this : y=18.75 and zi=25i ?
bump
astrololo said:
edit
I just made it up, it's a dummy variable.
No, hang in there with me for a second, I want you to expand ##(y+zi)^2## first. Then equate the parts that still have an i to the imaginary part, and the parts of the equation that have no i to the real part as two equations.
Ok, one step at a time : http://www4f.wolframalpha.com/Calculate/MSP/MSP64521di37fi0318f781f00005eih08d4i137gf4g?MSPStoreType=image/gif&s=22&w=132.&h=18.
Which gives y^2+2yzi-z^2
Excellent. Now combine like terms and tell me which are the real and complex parts and equate them to the right side respectfully.
y^2+2yzi-z^2
y^2-z^2 is the real part and 2yzi is the complex part.
astrololo said:
y^2+2yzi-z^2
So the real part is equal to your first equation, and the complex part is equal to second, why don't you go ahead and write that out.
y^2-z^2=18,75
2yzi=25i
astrololo said:
y^2-z^2=18,75
2yzi=25i
Yes, so a=18.75, and b =25.
So now you have two questions, solving equation 2 for $$z=\frac{b}{2y}$$ subbing it into equation one gives you $$y^2-(\frac{b}{2y})^2=a$$ which can be rewritten as $$4y^4-4ay^2-b^2=0$$ taking the positive root $$y^2=\frac{a+\sqrt{a^2+b^2}}{2}$$ which gives you $$y=\frac{1}{\sqrt{2}}\sqrt{a+\sqrt{a^2+b^2}}$$
That's the part of your real root, see if you can develop the complex part.
You shouldn't have given up on the quadratic formula so easily. With complex numbers, things tend to get algebraically messy, so you have to accept more complications than with real numbers. In any case, using the quadratic formula directly gives:
##x = \frac{14 + 5i \pm 5 \sqrt{3 + 4i}}{2}##
Which is really not very complicated at all!
Likes Student100
FAQ: Calculating the roots of a quadratic with complex coefficien
What is a quadratic equation with complex coefficients?
A quadratic equation with complex coefficients is an equation of the form ax2 + bx + c = 0, where a, b, and c are complex numbers. Complex numbers are numbers that contain both a real and an imaginary part, and are written in the form a + bi, where a and b are real numbers and i is the imaginary unit.
How do you calculate the roots of a quadratic equation with complex coefficients?
The roots of a quadratic equation with complex coefficients can be calculated using the quadratic formula: x = (-b ± √(b2 - 4ac)) / 2a. The ± symbol means that there are two possible solutions, one with a plus sign and one with a minus sign. This formula works for all quadratic equations, whether the coefficients are real or complex.
Can a quadratic equation with complex coefficients have real roots?
Yes, a quadratic equation with complex coefficients can have real roots. This occurs when the discriminant (b2 - 4ac) is a positive real number. In this case, the ± symbol in the quadratic formula will produce two real solutions.
What do the roots of a quadratic equation with complex coefficients represent?
The roots of a quadratic equation with complex coefficients represent the points where the graph of the equation crosses the x-axis. In other words, they are the values of x for which the equation is equal to 0.
What is the difference between real and complex roots in a quadratic equation?
The difference between real and complex roots in a quadratic equation is that real roots are values of x that are real numbers, while complex roots are values of x that are complex numbers. Real roots can be plotted on a traditional x-y coordinate system, while complex roots require a complex plane with both a real and imaginary axis to be represented.
