Calculating the Speed of a Plane for a Stationary Sun at 26.3° Latitude
In summary, to determine the speed at which a plane must fly at a latitude of 26.3° so that the sun stands still relative to the passengers, one must use the equation v=2πr/T where r is the radius of the circle at the latitude and T is the period of 24 hours. The radius can be found using the cosine of the latitude and the Earth's radius of 6.37x10^6 meters.
Tina20
38
How fast must a plane fly at a latitude of 26.3° so that the sun stands still relative to the passengers?
I have no idea how I can solve this question. I would like to draw a free-body diagram, but I don't know how to do that either. If I could at least draw a diagram, it would help me to think through this question.
I believe that the plane is 26.3 degrees above the equator, flying around the earth. So it is a circular motion question.
I don't have an acceleration, now do I have a period, but I think that the period might be one rotation around the earth, so 24 hours is one period? Also, the radius of the Earth is 6.37e6 m. angular velocity = speed/radius and angular velocity = 2pi/period
You indeed have a period of 24 hours.
The radius of the circle at a latitude of 26.3 degress is the distance from the Earth's axis to any point of this circle.
draw a picture of a crosssection through the Earth along the Earth's axis.
Thank you! I drew the free body diagram, found the radius using 6.37x10^6 cos 26.3 deg. and then substituted the radius and the period (T) --> (24hours = 86400 sec) into v= 2pir/T and got the answer :)
Why do u need to know the freebody diagram?
As a scientist, it is important to approach any problem systematically and logically. In this case, we are trying to calculate the speed of a plane at a specific latitude so that the sun appears to be stationary to the passengers.
First, we need to understand the motion of the plane and the sun. The plane is flying in a circular path around the Earth, while the sun appears to move across the sky due to the Earth's rotation. At the latitude of 26.3°, the plane is still moving in a circular path, but the angle at which it intersects the Earth's axis is different compared to the equator.
To solve this problem, we can use the equation v = ωr, where v is the speed of the plane, ω is the angular velocity, and r is the radius of the circular path. We know that the angular velocity is equal to 2π divided by the period of rotation, and the period of rotation is 24 hours. We also know that the radius of the Earth is 6.37e6 m.
Therefore, we can calculate the speed of the plane by plugging in these values into the equation v = (2π/24 hours) x (6.37e6 m). This gives us a speed of approximately 463.8 m/s. This means that the plane must fly at a speed of 463.8 m/s in order for the sun to appear stationary to the passengers at a latitude of 26.3°.
In terms of drawing a free-body diagram, it may not be necessary in this case as we are dealing with circular motion and not forces. However, if you were to draw one, you could show the forces acting on the plane, such as the gravitational force from the Earth and the centripetal force keeping the plane in its circular path.
Overall, this problem can be solved by understanding the motion of the plane and the sun, and using the appropriate equations to calculate the speed of the plane. It is important to approach any problem in a systematic and logical manner, and to use all the given information to arrive at a solution.
Related to Calculating the Speed of a Plane for a Stationary Sun at 26.3° Latitude
1. What is circular motion?
Circular motion is a type of motion in which an object moves along a circular path, constantly changing direction while maintaining a constant speed.
2. How does the latitude of 26.3 degrees affect circular motion?
The latitude of 26.3 degrees has no direct effect on circular motion. However, it does affect the orientation of the circular path with respect to the Earth's axis.
3. Why does the sun appear to stand still at this latitude?
The sun appears to stand still at this latitude due to the tilt of the Earth's axis, which causes the sun's position in the sky to appear to change throughout the day.
4. Is circular motion possible without a constant speed?
No, circular motion requires both a constant speed and a change in direction. If either of these components is missing, it is not considered circular motion.
5. How does circular motion relate to the laws of motion?
Circular motion follows the laws of motion, specifically Newton's first law of motion, which states that an object in motion will continue to move in a straight line at a constant speed unless acted upon by an external force. In circular motion, the external force is the centripetal force that keeps the object moving along its circular path.
