Calculating the Spring Constant k of a Spring
In summary, the value of the spring constant k for a spring that has been stretched by a distance of 0.20m with 30J of work is D) 1500. In order to find the value of k, the formula k=mg/x can be used. Another example of using formulas to solve problems is finding the kinetic energy at point B in a roller coaster ride, where the initial kinetic energy is 0 and the work done against friction is 30,000J. The formula KE(a) + PE(a) = KE(b) + PE(b) can be modified to incorporate the energy lost to friction, resulting in a final answer of 40,560 for the kinetic energy at point B.
jimithing71
To stretch a spring a distance of 0.20m 30J of work is done. What is the value of the spring constant k of the spring?
a)6 b)30 c)150 d)1500 e)none of the above
I know that the answer is D 1500 but I can't quite arrive at that.
The two formulas I thought to try were F=-kx and PE=1/2kx^2 but those didn't work. Then, after a bit of perusing on here I found k=mg/x.
Thus, 30(9.8)/.20 = 1470 ...which is close to 1500 but is that correct??
Try again. Note that these formulas are for very different things. Only one of them relates to work/energy.
Nah.
My head is starting to hurt! LOL!
Okay, so now I tried F=-kx, 30J=-k(.20m), 30J/.20m=-k, 150=k
That is one of the options (C), but our instructor told us the answer was (D) 1500. ?
You picked the wrong equation. F is force, not work. (PE is energy/work)
One more time.
Thank you! PE=1/2kx^6, 30=1/2k(.04), 30/.04=1/2k(.04)/.04, 750=1/2k, 1500=k Whew!
One more?
A roller coaster car with a mass of 900kg starts at rest from a point 20m above ground. At point B it is 12m above ground. If the initial KE was 0 and the work done against friction between the starting point and point B is 30,000J, what is the KE at point B?
a)10.8kJ b)20kJ c)30dj d)40kJ e) none of the above.
I know the answer is 40 kJ but I'm not sure which equation to use at all. The only one in my notes that seems close is KE=1/2mv^2 but that isn't working.
You need to worry about total mechanical energy: KE + PE. What's the formula for gravitational PE?
G=6.67X10^-11* N*m^2/kg^2 ??
Or wait! Is it PE=mgh??
yes it is
cupid.callin said:
yes it is
Which one?
That's the one.
Sorry but I don't get that at ALL! That would be PE=(900kg)(9.8g)(20m), PE= 176,400? What am I missing?
You need to compare total mechanical energy at the starting point to that at point B. What happens to the total mechanical energy because of friction?
It would be slowed due to friction? I am really lost on this one. I did the PE=mgh for point A and for point B and subtracted the two and got 70,560 so obviously that is wrong as well.
Hint: If there were no friction, then:
KEA + PEA = KEB + PEB
How would you have to modify this to incorporate the energy lost to friction?
I wish I knew!
Okay, last attempt:
0 + 176,400 = KE(b) + 105,840 + 30,000
176,400 - 105,840 - 30,000 = KE(b)
40,560 = KE(b)
jimithing71 said:
I wish I knew!
Okay, last attempt:
40,560 = KE(b)
Looks OK to me. One of the answer choices is pretty close.
Is that it?
jimithing71 said:
Is that it?
Yep. (Round off to one significant figure.)
LOVE YOU Doc Al! Thanks for all your help! Time for a glass of vino! :0)
FAQ: Calculating the Spring Constant k of a Spring
How do I measure the displacement of a spring?
To measure the displacement of a spring, you will need a ruler or a measuring tape. Place one end of the ruler at the original position of the spring and measure the distance to the end of the spring after it has been stretched or compressed.
What is the formula for calculating the spring constant k?
The formula for calculating the spring constant k is k = F/x, where F is the force applied to the spring and x is the displacement or change in length of the spring.
Can the spring constant k change?
Yes, the spring constant k can change depending on factors such as the material and thickness of the spring, as well as the temperature and amount of stress applied to the spring.
How do I determine the units for the spring constant k?
The units for the spring constant k depend on the units used for force and displacement. If the force is measured in Newtons and the displacement is measured in meters, then the units for k would be N/m.
Why is calculating the spring constant k important?
Calculating the spring constant k is important because it helps us understand how the spring will behave when a force is applied to it. It also allows us to make predictions about the behavior of springs in different situations and to design and use them effectively in various applications.
