Calculating the theoretical force of repulsion between two magnets
Calculating the theoretical force of repulsion between two magnets involves considering factors such as distance, relative orientation, and size. The discussion highlights that the formula for this force is complex and not straightforward. A referenced Wikipedia page provides examples of different magnet configurations. Participants clarify the relationship between force and distance, correcting terminology from "inverse exponential" to "inverse square." Understanding these principles is essential for accurate calculations in magnetism.
B-RY
I have been asked to complete a student experiment in which I decided to describe the inverse exponential relationship between the force of repulsion and the distance between two magnets.
I was wondering whether it be possible to calculate the theoretical value for the force at each distance?
I found this formula on the internet: F=K((m1m2)/((mu)xr^2))
Any help would be much appreciated! Thanks
Not only distance but relative NS direction angle and even size of magnet matter. The general formula between the magnets is rather complicated. The formula you referred is force between hypothetical magnet charges as if N and S were separable. https://en.wikipedia.org/wiki/Force_between_magnets shows some examples of various configurations.
Thankyou!
Inverse exponential!?
Inverse quadratic maybe.
Inverse square. My bad.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
