Calculating the Value of (1+i)^56
  • MHB
  • Thread starter Petrus
  • Tags
    Value
In summary: Re: polar formWell it's pretty useful. You can derive it easily:$$\sum_{k = 0}^n a^k = a^0 + a^1 + a^2 + \cdots + a^n = S$$$$aS = a^1 + a^2 + a^3 + \cdots + a^{n + 1} = S + a^{n + 1} - a^0$$$$(a - 1)S = a^{n + 1} - 1$$$$S = \frac{a^{n + 1} - 1}{a - 1} = \frac{
Petrus
702
Hello MHB,
I got no clue about that, well I start wounder but I don't think so but is that same as
\(\displaystyle (\frac{1}{\sqrt{2}}+\frac{i}{\sqrt{2}})^{56}\)
then I could go to polar form and get
\(\displaystyle r=1\) that means \(\displaystyle cos\theta=\frac{1}{\sqrt{2}} \ sin\theta=\frac{1}{\sqrt{2}}\) that means we got \(\displaystyle (e^{i\frac{\pi}{4}})^{56} <=>e^{i14\pi} \) so we got \(\displaystyle 1^{56}(1+0i) =1\)
Is this correct?
Regards,
\(\displaystyle |\rangle\)
Re: polar form
You have correctly found the last term of the summation.
I would try writing the summation in trigonometric form using de Moivre's theorem...
Re: polar form
Petrus said:
Hello MHB,
Is this correct?
Regards,
Well... you've only got the last term.
Which term do you get for k=0? And k=1? k=2? k=3?
Re: polar form
Is this correct?
\(\displaystyle \cos(\frac{\frac{\pi}{4}}{56}+\frac{k2\pi}{56})+ \sin(\frac{\frac{\pi}{4}}{56}+i \frac{k2\pi}{56})\) k=0,1,2,3..,56
Regards
Re: polar form
Plotting the first few partial sums in the complex plane may provide some insight..
(it draws regular octagons.. why? what happens at the last partial sum?)
Re: polar form
You can use
\(\displaystyle \sum^{n}_{k=0} e^{ix k}= \frac{1-e^{(n+1)ix}}{1-e^{ix}}\)
Re: polar form
Petrus said:
Is this correct?
Regards
Nope. It's not. Both the $i$ and the $k$ are misplaced.
Re: polar form
ZaidAlyafey said:
You can use
Your number is really \(\displaystyle \alpha = \exp \left( \frac{i\pi }{4} \right)\).
Show that \(\displaystyle \sum\limits_{k = 0}^7 {{\alpha ^k}} = 0\)
This repeats in blocks of eight.
So only \(\displaystyle \alpha^0\) is left.
Re: polar form
Hm... I get \(\displaystyle \cos(\frac{\frac{\pi}{4}}{56}+\frac{k2\pi}{56})+i \sin(\frac{\frac{\pi}{4}}{56}+ \frac{ik2\pi}{56})\) k=0,1,2,3..,56
What I am doing wrong?
Regards,
Re: polar form
Regards,
For each term you've got \(\displaystyle (e^{i\frac \pi 4})^k = e^{i \frac {k\pi} 4} = \cos \frac {k\pi} 4 + i \sin \frac {k\pi} 4\)
Somehow it just doesn't look the same.
Re: polar form
Show that \(\displaystyle \sum\limits_{k = 1}^7 {{\alpha ^k}} = 0\)
This repeats in blocks of seven.
but you should start from k=0 , to get 0 .
Re: polar form
Hello MHB,
Thanks for all responed but I totaly got confused. I need to read over my book and see if I missed something, I totaly got confused and don't understand...\(\displaystyle |\rangle\)
Re: polar form
Petrus said:
Hello MHB,
Thanks for all responed but I totaly got confused. I need to read over my book and see if I missed something, I totaly got confused and don't understand...\(\displaystyle |\pi\rangle\)
Okay...
What is it you got confused over? And that you don't understand...?
Re: polar form
I like Serena said:
Okay...
I just got diffrent tips. I just lost myself, in facit it says use the trick zaid said. \(\displaystyle \sum^{n}_{k=0} e^{ix k}= \frac{1-e^{(n+1)ix}}{1-e^{ix}}\)[/QUOTE]
but I can't find that in my book, I don't understand where it comes from
Regards,
Re: polar form
It's just the geometric series partial sum formula, with $e^{ix}$ as a base.
$$\sum_{k=0}^n a^k = \frac{1 - a^{n+1}}{1 - a}$$
Do you know this formula?
Re: polar form
Nop, I have not seen it. is this something famous formula?
Regards,
Re: polar form
$$S = \frac{a^{n + 1} - 1}{a - 1} = \frac{1 - a^{n + 1}}{1 - a}$$
Now let $a = e^{ix}$ and you have the formula you were confused about. It still works for complex numbers :)
The sum to infinity is similar except in that case there is no $a^{n + 1}$ obviously so you just get $\frac{1}{1 - a}$ :p (only if $|a| < 1$ of course otherwise the sum does not converge)
Re: polar form
Hello,
Thanks evryone! Now I understand!
Regards,
Re: polar form
Hey Petrus,
As others hinted at, this is what I wanted you to write:
\(\displaystyle S=\sum_{k=1}^{56}\left(\cos\left(\frac{k\pi}{4} \right)+i\sin\left(\frac{k\pi}{4} \right) \right)\)
and then look at:
\(\displaystyle S=7\sum_{k=1}^{8}\left(\cos\left(\frac{k\pi}{4} \right)+i\sin\left(\frac{k\pi}{4} \right) \right)=7\cdot0=0\)
FAQ: Calculating the Value of (1+i)^56
What does (1+i)^56 represent?
(1+i)^56 represents the value of an investment after 56 periods, where i is the interest rate per period. It is used in compound interest calculations.
How do you calculate the value of (1+i)^56?
To calculate the value of (1+i)^56, you can use the formula V = P(1+i)^n, where V is the future value, P is the present value, i is the interest rate per period, and n is the number of periods. Plug in the values for P, i, and n to find the future value.
What if I don't know the interest rate or number of periods?
If you do not know the interest rate or number of periods, you will need to gather more information in order to calculate the value of (1+i)^56. This may involve consulting with a financial advisor or using other financial tools to estimate the interest rate and number of periods.
Can (1+i)^56 be negative?
No, (1+i)^56 cannot be negative. The value will always be positive because it represents the future value of an investment.
How accurate is the value of (1+i)^56?
The accuracy of the value of (1+i)^56 depends on the accuracy of the input values. If the interest rate and number of periods are estimated or rounded, the calculated value may not be exact. However, the more accurate the input values, the more accurate the calculated value will be.
