Calculating the Value of $f(m,n)$
  • MHB
  • Thread starter juantheron
  • Tags
    Value
In summary, the formula for calculating the value of $f(m,n)$ is $m+n$. This value cannot be negative as it is a sum of two positive values. The formula can still be used for non-integer values, but the result may not be a whole number. When either m or n is equal to 0, the value of $f(m,n)$ will be equal to the other non-zero value. $f(m,n)$ is specifically for calculating the sum of two values and cannot be used for other mathematical operations.
juantheron
247
Let $f(m,n) = 3m+n+(m+n)^2.$ Then value of $\displaystyle \sum_{n=0}^{\infty}\;\; \sum_{m=0}^{\infty}2^{-f(m,n)}=$
Take a look at $f(n,m).$
Might I ask where this question comes from?
The sum converges very quickly and can be evaluated numerically with 4 terms of each summation (it is \(\approx 1.33333\), which is very suggestive ... ) to good accuracy.
CB
(why the previous calc got the wrong answer I still have no idea)
I hope Krizalid will not object if I add a bit to his very helpful suggestion. In problems like this, my advice is always to start by looking at what happens for small values of the variables. In this case, if you make a table of the values of $f(m,n)$ for small values of $m$ and $n$, it looks like this:
$$\begin{array}{cc}&\;\;\;\;n \\ \rlap{m} & \begin{array}{c|cccc} &0&1&2&3 \\ \hline 0&0&2&6&12 \\ 1&4&8&14&. \\ 2&10&16&.&. \\ 3&18&.&.&. \end{array} \end{array}$$
Doesn't that suggest something very interesting about the range of the function $f(m,n)$?
It's from a Putnam. I don't remember the year though.
FAQ: Calculating the Value of $f(m,n)$
What is the formula for calculating the value of $f(m,n)$?
The formula for calculating the value of $f(m,n)$ is $m+n$.
Can the value of $f(m,n)$ be negative?
No, the value of $f(m,n)$ cannot be negative as it is a sum of two positive values.
How do you determine the value of $f(m,n)$ for non-integer values of m and n?
The formula for $f(m,n)$ can still be used for non-integer values of m and n, but the result may not be a whole number. It is important to clarify the desired precision of the result beforehand.
Is there any special case for calculating the value of $f(m,n)$?
Yes, when either m or n is equal to 0, the value of $f(m,n)$ will be equal to the other non-zero value. For example, $f(5,0) = 5$ and $f(0,7) = 7$.
Can $f(m,n)$ be used for other mathematical operations?
No, $f(m,n)$ is specifically for calculating the sum of two values and cannot be used for other mathematical operations such as multiplication or division.
