Calculating the value of R for a resistor in an RLC series circuit
In summary, for an RLC series circuit with a capacitance of 4.8mF, an inductance of 0.520H, and a source voltage amplitude of 56.0V, operated at resonance frequency, the value of R for the resistor can be found by using the equation I=ΔV/R, where I is the current, ΔV is the voltage across the capacitor, and R is the resistor. At resonance, the impedance of the series C and L is zero, so the voltage of the source will only appear across R. Therefore, R can be calculated by dividing the source voltage by the current flowing through the circuit.
quellcrist
1. An RLC series circuit has C= 4.8mF, L=0.520H, and source voltage amplitude V= 56.0V. The source is operated at the resonance frequency of the circuit. If the voltage across the capacitor has amplitude 80.0V, what is the vaule of R for the resistor?
2. ##I = (ΔVc)/(Xc)##,
##Xc= (1)/(ωc) ##,
## ω= (1)/(sqrt(LC)) ##
resonance frequency = ## (1)/(sqrt(LC)) = 20Hz##
##Xc= 10.4 ##
## Ic = IL = Ir ## in an RLC series circuit
therefore ## I= 80V/10.4 = 7.7##
At resonance frequency ##X=R##
Z is at a minimum
R is at a minimum, VL and VC cancel each other other becoming 0,
##Z= sqrt((R)^2+(XL-Xc)^2)##
##Vr=sqrt((ΔVtotal)^2-(ΔVL-ΔVc)^2)##
3. I know this question shouldn't be that hard but I have hit a mental block and cannot proceed. I know how to calculate impedance but the value of R isn't given. My question is "How do I calculate impedance when R is not given?" I know the RLC series circuit becomes purely resistive at resonance and that Z is at a minimum and Z=R. Thanks!
Maybe doublecheck your Xc calculation. Windows calculator gadget is giving me something different but it could be I misclicked something. I tend to get three different answers on three different attempts when I use this thing. EDIT: I was thrown by 20Hz for 1/√LC, it's 20 rad/s and then I get the same as you.
So does the value R across the resistor simply equal the value of the resistance across Vc and VL (Vc= 10.4Ω and VL=10.4Ω but since they are 180° out of phase they end up canceling each other out.) ?
I mean to say does R=10.4 ohms?
The impedances of the inductor and capacitor cancel out so that the full source voltage appears across R only. The voltage across the capacitor will be equal and opposite (ie 180 degrees out of phase) with the voltage across the inductor so that adding them results in zero.
You can see it like so:
Ic = I = Vc jwC
VL = I jwL = Vc jwC jwL = -Vc w2LC = -Vc
because at resonance, w2LC = 1Or more directly:
Zl+Zc = 0 so (Vc+Vl) = IZ = 0; Vl = -VcThe series current I flows through R, C and L but generates equal and opposite voltages across C and L so that Vs appears across R only.
This means R = Vs / I which you could also get from I = Vs/Z = Vs/(R + Zl + Zc) = Vs/RIt may seem a bit strange but that's because the problem is the reverse of what is normally asked. Usually you have the resistance from which you can calculate the series current I=Vs/R (since Zc and Zl cancel at resonance). And from there you can find the voltage across the capacitor as Vc=I jwC
Thank you for clarifying this for me. I noticed this problem was weird for the same reason you stated (usually they give you a value for R and then you proceed from there).
I rechecked and re-did all my calculations. Turns out that R does equal 10.4 ohms. I found this by finding the current across Ic (since Ic=IL=Ir). I took the current and set it equal to 56V/R and solved for R. I ended up with R= 10.4 ohms.
Related to Calculating the value of R for a resistor in an RLC series circuit
What is the formula for calculating the value of R in an RLC series circuit?
The formula for calculating the value of R in an RLC series circuit is R = V/I, where V is the voltage across the resistor and I is the current flowing through the resistor.
What is the unit of measurement for R in an RLC series circuit?
The unit of measurement for R in an RLC series circuit is ohms (Ω).
How do I measure the voltage and current in an RLC series circuit?
The voltage can be measured using a voltmeter, which is connected in parallel to the resistor. The current can be measured using an ammeter, which is connected in series to the resistor.
What is the significance of R in an RLC series circuit?
R represents the resistance of the resistor in the circuit. It determines how much the current will be reduced as it flows through the resistor. R also plays a role in determining the overall impedance of the circuit.
Can the value of R change in an RLC series circuit?
Yes, the value of R can change in an RLC series circuit. It can be adjusted by changing the physical properties of the resistor, such as its length, material, or temperature. Additionally, the value of R may change if other components in the circuit, such as capacitors or inductors, are added or removed.
