Calculating the velocity decrease going up an incline
In summary, the conversation discusses the factors involved in calculating the angular velocity of a car going up an incline. The questioner wants to know how the car's acceleration is affected when it travels at a consistent speed of 60mph on an even plane and then hits an incline. The answerer suggests using the formula (1/2)(mv^2) =mgR(1-cosx) to find the car's velocity on the incline, taking into consideration the force of air resistance and gravity. They also mention the importance of understanding force diagrams to fully understand the concept.
Niaboc67
249
I know there are many factors that go into this. But in general how would one go about calculating the angular velocity for a car going up an incline. What I want to know in particular is if a car say is driving at a consistent speed of 60mph on an even plane and then hits an incline up wards at 45* going the speed the person is going at what rate is the car's acceleration decreased. I'd think it must be a gradient going slower and slower as the incline increases in steepness. If someone could explain this and then give a mathematical equation that would be greatly appreciated.
Thanks
Assuming its a circular incline going steeper and becomes vertical
As the car covers angle x in the incline
Conserve energy(neglecting friction)
##(1/2)(mv^2) =mgR(1-cosx)##
From there you can find v(x)
Can you make the question more clearer
Well, if you discount the rolling resistance of the tires/drive train, at the fixed output power of the engine when traveling 60 MPH, the force vectors are all in the same horizontal plane: The force of air resistance is matched by the engine's output. For a given object, air resistance is proportional to velocity squared.
On the inclined plane, you must break the velocity vector into the horizontal and vertical components. (At 45 degrees , the horizontal and vertical speed components are equal, and both equal the velocity divided by the square root of 2.)
On an inclined plane, the fixed engine output must be sufficient to lift the car's mass against the force of gravity. Since overcoming the drag at 60 MPH would be on the order of 20 HP/15KW, it is entirely possible that this 'fixed' output would not be enough to lift the car at all, unless the speed dropped to near zero. (in real life, given most vehicles gear reduction range, it's probable that a car would not be able to go up this steep an incline at all.) At 45 degrees, the force vector due to gravity is split into the horizontal and vertical components by dividing mass by sqrt(2), also. And, the air resistance vector, which is parallel to the plane, would need to be included needs to be included in the solution as well.
I really think you should take a look at the force diagrams and explanations at the lesson on inclined planes here. Diagrams are helpful in understanding the forces involved.
Related to Calculating the velocity decrease going up an incline
What is the formula for calculating velocity decrease going up an incline?
The formula for calculating velocity decrease going up an incline is v = v0 - gsinθt, where v is the final velocity, v0 is the initial velocity, g is the acceleration due to gravity, θ is the angle of the incline, and t is the time taken to reach the top.
How does the angle of the incline affect the velocity decrease?
The steeper the incline, the greater the velocity decrease. This is because the component of gravity acting in the direction of motion increases as the angle of the incline increases, resulting in a larger decrease in velocity.
What is the role of time in calculating velocity decrease going up an incline?
Time is a crucial factor in calculating velocity decrease going up an incline. It is used to determine the amount of time taken to reach the top of the incline and is incorporated into the formula as t. The longer the time taken, the greater the decrease in velocity.
How does the initial velocity affect the velocity decrease?
The initial velocity, v0, plays a significant role in determining the velocity decrease. A higher initial velocity will result in a larger decrease in velocity going up an incline, while a lower initial velocity will result in a smaller decrease.
Are there any other factors that affect the velocity decrease going up an incline?
Apart from the angle of the incline, initial velocity, and time, there are a few other factors that can affect the velocity decrease. These include air resistance, friction, and the mass of the object. However, these factors may have a minimal impact on the overall velocity decrease in most cases.
