Calculating the waste heat of Carnot engine
The discussion centers on calculating the waste heat of a Carnot engine, with an initial waste heat estimate of 7405.9 J, which was later corrected to 6470 J. The efficiency was calculated as 0.35481 using the temperatures converted to Kelvin. Participants emphasized the importance of using the correct formulas for efficiency, specifically e = 1 - Qout/Qin, to avoid algebraic errors. It was suggested to solve the problem without numerical values for clarity and accuracy. The conversation highlights the need for precise expressions in thermodynamic calculations to ensure correct results.
JoeyBob
See attached
e=1-(Tc/Th)
e=W/Qin
e=(Qin-Qout)/Qout
The answer is 6470 J.
So since I have the two temperatures I could calculate the efficiency. First I convert to kelvin then get an efficiency of 0.35481. Now I can use e=W/Qin to get Qin. I get a value of 10033.54J.
Now I can use e=(Qin-Qout)/Qout to get Qout, the waste heat. I get 7405.9 J.
Overview of calculations:
e=1-(295.66/458.25)=0.35481
Qin=W/e=3560/0.35481=10033.54 J
Qout=Qin/(e+1) = 10033.54/(1.35481) = 7405.9 J but answer is 6470 J.
It looks like you messed up the algebra. I agree with your number for the efficiency but not with one of your expressions for it. For best results, try solving this without numbers, a recommendation that was made to you before.
You have ##e=1-\dfrac{Q_{out}}{Q_{in}}## and ##e=\dfrac{W}{Q_{in}}##. Can you eliminate ##Q_{in}## and get an expression relating ##Q_{out}## to ##e## and ##W?##
kuruman said:
It looks like you messed up the algebra. I agree with your number for the efficiency. Try solving this without numbers, a recommendation that you have so far ignored.
You have ##e=1-\dfrac{Q_{out}}{Q_{in}}## and ##e=\dfrac{W}{Q_{in}}##. Can you eliminate ##Q_{in}## get an expression relating ##Q_{out}## to ##e## and ##W?##
Qin=W/e so
e=1-Qout/(W/e)
e=1-eQout/W
1-e=eQout/W
(1-e)W/e = Qout
(1-0.35481)*3560/0.35481
Youre right, must have messed up my algebra somewhere because this gives the right answer.
Thanks.
It's not the algebra, it's this: e=(Qin-Qout)/Qout.
When Qout = 0 you should expect efficiency of 1. Your expresion does not predict that. That is why I prefer to write it as ##e=1-\dfrac{Q_{out}}{Q_{in}}.## It reduces to 1 when no heat is wasted. I am mentioning this so that you will write the correct expression next time.
I would never go to the efficiency to solve this. I would write $$Q_{in}-Q_{out}=W$$ and $$\frac{Q_{in}}{T_{hot}}-\frac{Q_{out}}{T_{cold}}=0$$This is two linear algebraic equations in two unknowns.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
31K
9K
