MHB Calculating theoretical probability
The discussion revolves around calculating the theoretical probability of drug effectiveness in a sample of ten from a batch of 40,000. It is established that a drug is four times more likely to succeed than to fail, leading to the conclusion that the scenario can be modeled using a binomial distribution. Participants emphasize that the drugs should be assumed to succeed or fail independently. To find the probability of at most three drugs failing, one must first solve for the success probability, p, using the relationship p = 4(1-p). This approach provides a structured method for addressing similar probability problems in the future.
bhuv
Hello All,
I have the following question in one of my tutorials. I need some help in resolving this.
Background: A manufacturing company developed 40000 new drugs and they need to be tested.
Question
The QA checks on the previous batches of drugs found that — it is 4 times more likely that a drug is able to produce a better result than not.
If we take a sample of ten drugs, we need to find the theoretical probability that at most three drugs are not able to do a satisfactory job.
a.) Propose the type of probability distribution that would accurately portray the above scenario, and list out the three conditions that this distribution follows.
b.) Calculate the required probability.Thanks,
Vicky
bhuv said:
Hello All,
Question
Vicky
Which distributions do you know in probability? are we looking at discrete or continuous data?
This thread is four years old, I doubt the op is still working on it.
In case anyone else stumbles on this and is looking for guidance for a similar problem: if a drug is p to succeed and 1-p to fail, they tell us in the problem that p=4(1-p). You can solve for p from here. The question probably wants you to assume that the drugs each succeed or fail independently in your sample of ten.
Likes chwala and Greg Bernhardt
...Binomial distribution would address this.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
