MHB Calculating Time for Iodine 131 to Decay to 5% of Initial Dose
To determine when iodine-131 decays to 5% of its initial dose, the equation D(t) = D0 * 2^(-t/8) is used. By setting D(t) equal to 0.05D0, the equation can be rearranged to solve for time t. This involves calculating the logarithm to isolate t, leading to the formula t = -8 * log2(0.05). The final result will provide the time in days until the iodine-131 is undetectable.
Pikachu1
So i have a graph representing iodine 131
y axis of 0-100 iodine remaining in the body (%of dose)
x asis 0-60 Time in days
with the points plotted (24,12.5)
The equation of the graph is D = D0 (b) t/k
So i have figured out "k" which is 8 for iodine half life. Which it asked me to do in the previous question.
Now it is asking me...
Iodine 131 is unable to be detected after it has decayed to 5% of its initial dose. Using your equation, determine how many days, to the nearest tenth will have passed until the dose is undetectable.
Just not sure how to use my equation to get that answer. I realize it's simple but it is out smarting me.
Mathematics news on Phys.org
Okay the curve is:
$$D(t)=D_02^{-\frac{t}{8}}$$
To find the time at which the initial dose has decayed to 5% of the original amount, you may set $D(t)=0.05D_0$ and then solve for $t$. Can you proceed?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
