Calculating torque to turn/twist a trailer on wheels when it's not moving
  • Thread starter Thread starter Calvin Horst
    new member
The discussion centers on constructing a mobile building for pastured chickens, measuring 24' by 44' and weighing approximately 16,000 pounds when loaded. The builder is considering using smooth balloon tires for easier movement and plans to pull the structure with a winch. Key considerations include the structural integrity of the chassis, the alignment of wheels during movement, and the building's ability to withstand wind. Participants emphasize the importance of design and cross-bracing for stability, as well as the need for a visual sketch of the proposed structure. Overall, the focus is on ensuring the building can be effectively maneuvered in various field conditions.
Calvin Horst
How did you find PF?: web search.
I am new to all this. There was another post similar to this, but it was above my current education. I didn't go beyond 8th grade. So, beyond that I learn by doing, and through other friends.
I'm constructing a building on wheels for pastured chickens. 24' wide, 44' Long and weight roughly 16,000 pounds when loaded. Building is capable of moving sideways and end ways.
Wheels are 31" diameter 15" wide with bar tread 4.5" O.C. 1.5" wide bar standing 0.625" high. And 3" in-between the bars. 4 wheels = 4,000 lbs. per wheel.
I am considering putting smooth Balloon tires on which would turn much easier. And pulling the building with a winch.
Another factor is how muddy the field is.
Welcome to PF. :smile:
Dat's a lot of chickens! Do you have any pictures of similar structures/trailers?
AKA Chicken tractor. https://en.wikipedia.org/wiki/Chicken_tractor
https://mobilechickenhouse.com/commercial-chicken-tractor/
How many wheels? To move the structure, you will need to pull on all the wheel modules at the same time. The direction of the pull will need to align the individual wheels.
The problem will be the strength of the framework or chassis. That will come down to the structural design, and how wires are used for cross-bracing.
Wind design will be important. What are the strongest winds it must withstand? What will the walls and roof be made from?
We need a sketch of your basic ideas.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
