Calculating Train Deceleration: Solving a Homework Problem in 4 Steps
Lastly, use the fact that the train is decelerating (a is negative) to solve for the unknowns.In summary, the problem involves finding the value of the acceleration of a train that stopped 75 meters from an observer, given that the first and second train cars passed the observer in 4 seconds and 5 seconds respectively. This problem can be solved using simultaneous equations and the fact that the train is decelerating.
Milos Zivkovic
A person standing on a train platform notices that the first train car, which is approaching the station, had passed him in 4 seconds, and that the second train car passed him in 5 seconds. After this, the front of the train stopped at the distance of 75 meters from the person. Assuming the deacceleration of the train is constant, find its value.
The problem was translated, so I apologize for any mistakes.
( V - Velocity, D - Distance, t - Time)
V = D/t
V= Vo + a*t
V2=Vo2 +2a*D
D= Vo*t + at2/2
I tried to solve it using integrals, but no luck. I am not sure how to break down this problem and solve it accordingly.
The answer should be: -0.25 m/s2
Please show your actual work.
Integrals are not needed. It can be solved by simultaneous equations. Focus on the distance of the front of the train from the observer.
Choose some unknown quantities whose values we want to find - for instance L for the length of a carriage, a for the acceleration and u for the initial velocity when the front of the train passes the observer. However many unknowns you have, that's how many equations you need to be able to solve for them. For example, using the equations you wrote above, you should be able to write at least three equations, one for each of the following periods:
1. while first carriage is passing observer
2. while second carriage is passing observer
3. from end of second period to when train is stopped
Related to Calculating Train Deceleration: Solving a Homework Problem in 4 Steps
What is the formula for calculating train deceleration?
The formula for calculating train deceleration is a = (vf - vi) / t, where a is the deceleration, vf is the final velocity, vi is the initial velocity, and t is the time taken to decelerate.
What units should be used when calculating train deceleration?
The units used when calculating train deceleration will depend on the units of the given values. However, commonly used units include meters per second squared (m/s^2) or kilometers per hour squared (km/h^2).
What are the 4 steps involved in solving a train deceleration homework problem?
The 4 steps involved in solving a train deceleration homework problem are: 1) Identify the given values, 2) Determine the formula to use, 3) Substitute the values into the formula, and 4) Calculate the deceleration.
How does the mass of the train affect the deceleration?
The mass of the train does not directly affect the deceleration. However, a heavier train may require a longer distance or more force to decelerate compared to a lighter train.
How can train deceleration be applied in real-life situations?
Train deceleration can be applied in real-life situations to ensure the safety and efficiency of train travel. It can also be used in the design and maintenance of train tracks and brakes. In addition, understanding train deceleration can help engineers improve the overall performance of trains and reduce energy consumption.
9K
