Calculating uncertainty with a set of angles
In summary: This makes sense because you can see how much better you can measure n when the incident angle is 45 than when it is 1.Those two measurements clearly have different error and shouldn't be given the same importance.
zexxa
32
Hi there, the issue I'm having right now is finding the right way to calculate uncertainties when trigonometric terms come in play.
The question goes like this, we're given 2 sets of 5 angles in degrees, the incident angle (10.0, 20.0, 30.0, 40.0, 50.0) and the other is the refracted angle (6.9, 13.6, 20.0, 25.4, 31.1). The measurements were taken with an analogue protractor with a ±0.1° resolution.
The refractive index n is to be calculated with it's standard uncertainty.
[tex]
n = \frac{sin(α)} {sin(β)}
[/tex][tex]
dn = \sqrt { (\frac {δn} {δα} dα)^2 + (\frac {δn} {δβ} dβ)^2}
[/tex]
I first tabulated the data and found n for each α,β entry and averaged all 5 values of n which was 1.466461.
The standard deviation of n is 0.024073, which then I used to find its Type A uncertainty with the equation [tex]u=\frac{σ}{\sqrt 5}[/tex]
When I tried to find the Type B uncertainty however, I hit a wall. This was rest of my work:
[tex]
\frac {δn}{δα}=\frac {cos(α)} {sin(β)}
[/tex][tex]
\frac {δn}{δβ}=\frac {-sin(α) cos(β)} {sin(β)^2}
[/tex][tex]
∴dn= \sqrt {n^2 (cot(β)^2 dβ^2 -dα^2) + \frac{dα^2}{sin(β)^2}}
[/tex]
I do not know what I should substitute in place of β when calculating since the value of β is a dependent variable in the experiment and have been at a loss for a few days.
Hello zexxa, :welcome:
With quotients and products it's always easier to work with relative errors, like here $$ {\delta n\over n} = {\delta\alpha\over\tan\alpha} - {\delta\beta\over\tan\beta}$$
I copied your data to a spreadsheet and found ##n = 1.4687 ## as average, not your 1.466. And sigma 0.0217, not 0.0241
A typo ?
Hi BvU
Oh dear I put in the wrong numbers in my excel spreadsheet, your values there are right.
To be honest I don't see how you arrived at [tex]{\delta n\over n} = {\delta\alpha\over\tan\alpha} - {\delta\beta\over\tan\beta}[/tex]
I've been deriving the uncertainties using the second equation under "Relevant Equations" and can't seem to resolve my answer to match yours. But regarding your relative error, the same issue will still arise - what would you substitute in α and β, since the readings are not similar?
[tex]
[/tex][tex]
[/tex]
[tex]
[/tex][tex]
[/tex][tex]
[/tex]
your derivatives are correct. I didn't check your algebra, but I presume your resulting expression for error is correct. For β you use the measured value for a single measurement. This gives you an error bar FOR THAT SINGLE MEASUREMENT. Each measurement will have a different error. Putting the measurements together to make a best estimate of n from all the measurements would then be a weighted average instead of a simple average giving more weight to the better measurements.
This makes sense because you can see how much better you can measure n when the incident angle is 45 than when it is 1. Those two measurements clearly have different error and shouldn't be given the same importance.
Likes zexxa and BvU
zexxa said:
Hi BvU
Good we found that :smile:
$$\frac {δn}{δα}=\frac {cos(α)} {sin(β)}\ \ \Rightarrow\ \ \frac {δn}{n} = \frac {\cos(α)} {\sin(β)} {\sin\beta\over\sin\alpha}{δα}$$and
$$\frac {δn}{δβ}=\frac {-sin(α) cos(β)} {sin(β)^2}\ \ \Rightarrow\ \ \frac {δn}{n} = \frac {-\sin\alpha \cos(\beta)} {\sin^2(β)} {\sin\beta\over\sin\alpha}{δ\beta}$$
If we assume the measurements of ##\alpha## and ##\beta## are independent we can add these constributions in quadrature.
(you want to use \cos and \sin in tex and don't need the brackets)
You want to insert the actual ##n, \ \alpha## and ##\beta## for each measurement and sum over the measurements.
The post by Cutter is a refinement in the sense that each measurement in fact has a different weight due to the absolute error in the angle measurement. So for all summation terms a weight factor enters.
Likes zexxa
Thanks very much @BvU and @Cutter!
Cleared up a lot of misconceptions and I understand how it works now!
P.S. Thanks for the Tex tips, still not used to it yet but I'll get the hang of it :)
Likes BvU
You are most welcome
Related to Calculating uncertainty with a set of angles
What is the purpose of calculating uncertainty with a set of angles?
The purpose of calculating uncertainty with a set of angles is to determine the range or margin of error for a set of measured angles. This can help in determining the accuracy and precision of the measurements and can be useful in various scientific and engineering fields such as astronomy, geology, and navigation.
How is uncertainty calculated for a set of angles?
Uncertainty for a set of angles can be calculated using statistical analysis methods such as standard deviation or confidence intervals. These methods take into account the variation of the measured angles and provide a numerical value that represents the uncertainty of the measurements.
What factors can contribute to the uncertainty of a set of angles?
There are several factors that can contribute to the uncertainty of a set of angles, including measurement errors, instrument limitations, and environmental conditions. The precision of the measuring instrument, the skill of the person taking the measurements, and external factors such as wind or vibrations can also affect the uncertainty of the angles.
How can uncertainty in a set of angles be reduced?
To reduce uncertainty in a set of angles, it is important to use precise measuring instruments, calibrate them regularly, and follow proper measurement techniques. Taking multiple measurements and calculating the average can also help to reduce uncertainty. Additionally, minimizing external factors and environmental conditions can improve the accuracy of the measurements.
What are the units of uncertainty for a set of angles?
The units of uncertainty for a set of angles are typically the same as the units of the measured angles. For example, if the angles are measured in degrees, the uncertainty would also be in degrees. However, it is important to note that uncertainty is a relative measure and does not have a specific unit, but rather represents a range or margin of error for the measured values.
13K
14K
12K
