Calculating Voltage Across Capacitor Using Node Method and Phasors
In summary, the speaker is trying to find the voltage at node Va in a circuit using the node method via phasors. They are wondering if Va is equal to (v1 - v2)/Zc, where v1 is the node voltage between the 1/2 F capacitors on the left and v2 is the node voltage between the 1/2 F capacitors on the right, or if it is just equal to v1 - v2. The speaker also mentions that Va is the voltage between the terminals of the middle 1/2 F capacitor in a blurry diagram. They are asking for help with the nodal analysis and for an equation to describe Va in terms of node voltages. The response advises
magnifik
360
i am trying to find va in the circuit below
i am using the node method via phasors and am wondering is va = (v1 - v2)/Zc??
or is it just equal to v1 - v2?
thanx
magnifik said:
i am trying to find va in the circuit below (it is kind of blurry, but va is the voltage between the terminals in the middle 1/2 F capacitor)
thanx
You are guessing.
Make a full attempt, otherwise you won't learn anything.
Label each of the two nodes above the inductors (say, node L and node R) and preform the nodal analysis. (i.e. KCL combined with Ohm's law)
Also, write an equation describing Va in terms of these node voltages.
Show us your equations/work.
Note that the units for (v1 - v2)/Zc are amperes... this should answer your question.
FAQ: Calculating Voltage Across Capacitor Using Node Method and Phasors
What is the definition of voltage across a capacitor?
Voltage across a capacitor is the difference in electric potential between the plates of the capacitor. It represents the amount of energy stored in the electric field between the plates.
How is voltage across a capacitor calculated?
Voltage across a capacitor can be calculated by dividing the charge on the capacitor by the capacitance, according to the equation V = Q/C. It can also be calculated by integrating the current over time, according to the equation V = (1/C) * ∫i(t)dt.
What is the relationship between voltage across a capacitor and the charge on the capacitor?
The voltage across a capacitor is directly proportional to the charge on the capacitor. This means that as the charge increases, the voltage across the capacitor also increases.
How does a change in capacitance affect the voltage across a capacitor?
A change in capacitance will directly affect the voltage across a capacitor. If the capacitance decreases, the voltage will increase, and vice versa. This is because the voltage is inversely proportional to the capacitance, according to the equation V = Q/C.
What factors can affect the voltage across a capacitor?
The voltage across a capacitor can be affected by factors such as the amount of charge, the capacitance, and the frequency of the current passing through the capacitor. The type of dielectric material used in the capacitor and the temperature can also have an impact on the voltage across the capacitor.
