Calculating work done by an Electric field on a positive charge
In summary, the electric field strength is E = 6 × 105 V / m, the displacement of the charge is s = 10 cm, and the work done is 4.2 * 10^-3 CV (m*kg*A^2 / s^2).
psy
Poster reminded to use the Homework Help Template in the future for schoolwork posts
Hey
How can i calculate the work done
by a homogeneous electric field on a positive charge q
= 7 × 10^-8 C when the charge moves from point 1 to point 2
. I have two cases:
a) the charge is parallel to the
Electric field;
b) the displacement of the charge takes place at the angle α = 60 °
to the
Electric field.
The electric field strength is E = 6 × 105 V / m, the displacement
https://www.flickr.com/photos/155324944@N02/35099011562/in/dateposted/
So the mechanical work equation is equivalent to the electrical
case a)
The force done on the particle is the electric field strength multiplied with its charge :
F = q * E = 7* 10^-8 C * 6 * 10^5 V/m = 42 * 10^-3 CV/m
The work is given by W = F*s = 42 * 10^-3 CV/m * 0.1 m = 4.2 *10^-3 CV ( m*kg*A^2 / s^2)
case b)
the particle is still moving in the same direction as the field force ,but a with an angle,
so i would use
F = q * E * cos(60°)
Is this a proper way to calculate it?
The first case (a) looks good to me. (The standard unit for work is the Joule.)
psy said:
case b)
so i would use
No, the equation is wrong. The electric force is proportional to the electric field, ##\vec F = q \vec E##
The problem text says that "b) the displacement of the charge takes place at the angle α = 60 °to the Electric field."
The charge is scalar, it does not have direction.
What is the work if the force and the displacement make an angle α ?
psy said:
case b)
so i would use
As ehild points out, that equation is incorrect. But it's a step in the right direction if you meant to give the component of the force in the direction of the displacement.
The link above requires one to have a flickr account, and even if one does it does not resolve to a valid destination. Please upload your image to the PF server so that members here don't have to follow offsite links or have accounts on other services in order to view them.
Related to Calculating work done by an Electric field on a positive charge
1. What is work done by an electric field on a positive charge?
The work done by an electric field on a positive charge is the amount of energy transferred to the charge as it moves through the field. It is measured in joules (J).
2. How do you calculate work done by an electric field on a positive charge?
The equation for calculating work done by an electric field on a positive charge is W = qEd, where W is work (in J), q is the charge (in coulombs), E is the electric field strength (in newtons per coulomb), and d is the distance the charge moved in the field (in meters).
3. What is the unit for work done by an electric field on a positive charge?
The unit for work done by an electric field on a positive charge is joules (J). This is the same unit used for measuring energy.
4. Can work done by an electric field on a positive charge be negative?
Yes, work done by an electric field on a positive charge can be negative. This occurs when the charge moves in the opposite direction to the direction of the electric field, meaning the field is doing work on the charge rather than the charge doing work on the field.
5. How does work done by an electric field on a positive charge affect the charge's potential energy?
The work done by an electric field on a positive charge increases the charge's potential energy. This is because work is being done to move the charge against the electric field, increasing the charge's potential to do work itself.
