MHB Calculating Work to Empty a Trapezoidal Trough: Jessica's Question
To calculate the work required to pump water out of a trapezoidal trough with a height of 5m, a bottom width of 2.5m, and a top width of 5m, the formula derived involves integrating the weight of water sheets at varying depths. The work is expressed as W = (length * density * height^2 / 6) * (2 * bottom width + top width). Substituting the given values, including the density of water (9800 N/m^3) and the length of the trough (15 m), results in a total work of 6.125 MJ. This approach effectively utilizes calculus to account for the varying width of the trough as water is pumped out. The final calculation confirms the total work needed to empty the trough when full.
MarkFL
MHB
Here is the question:
How much work is required to pump the water out of the trough when it is full?
A trough has a trapezoidal cross section with a height of 5m and horizontal sides of width 2.5m and 5m. Assume the length of the trough is 15m. How much work is required to pump the water out of the trough (to the level of the top of the trough) when it is full? Use 1000 kg/m^3 for the density of water and 9.8 m/s^2 for the acceleration due to gravity.
Please help!
W = Integrand p(<roe)gA(y)D(y)
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Hello .:Jessica:. Go Spartans!,
I prefer to work problems like this in general terms, and then plug our given data into the resulting formula.
First, let's let:
$$\ell$$ = the length of the trough.
$$h$$ = the depth of the trough.
$$b$$ = the width of the trough at the bottom.
$$B$$ = the width of the trough at the top.
$$s$$ = the distance above the top of the trough the fluid is to be pumped.
$$\rho$$ = the weight density of the fluid.
$$g$$ = the acceleration due to gravity.
Now, let's imagine slicing the contents of the tank horizontally into rectangular sheets. The length of each sheet is constant, given by the length of the tank $\ell$. The width $w$ of each sheet will be a function of its vertical position within the trough.
So, let's orient a vertical $y$-axis paasing though the axis of symmetry of a vertical cross-section, with its origin at the bottom of the trough.
We know that the width of the trough will vary linearly as we move up the $y$-axis, and will contain the two points:
$$(0,b),\,(h,B)$$
Hence, the slope of this linear function is given by:
$$m=\frac{\Delta w}{\Delta y}=\frac{B-b}{h}$$
And so, using the slope-intercept form of a line, we find:
$$w(y)=\frac{B-b}{h}y+b$$
And so the volume of an arbitrary sheet is:
$$dV=\ell\cdot w(y)\,dy=\ell\left(\frac{B-b}{h}y+b \right)\,dy$$
Next, we want to determine the weight $\omega$ of the arbitrary sheet. Using the definition of weight density, we may state:
$$\rho=\frac{\omega}{dV}\,\therefore\,\omega=\rho\,dV$$
Next, we want to determine the distance $d$ the arbitrary sheet must be lifted. This is:$$d=s+(h-y)$$
Thus, using the fact that work is the product of the applied force and the distance through which this force is applied, we find the work done to lift the arbitrary sheet is:
$$dW=\omega d=d\rho\,dV=\rho\left(s+(h-y) \right)\left(\ell\left(\frac{B-b}{h}y+b \right)\,dy \right)=\ell\rho\left((s+h)-y) \right)\left(\frac{B-b}{h}y+b \right)\,dy$$
After a bit of algebra, we may write:
$$dW=\frac{\ell\rho}{h}\left((b-B)y^2+\left(s(B-b)+h(B-2b) \right)y+bh(h+s) \right)\,dy$$
Now, if we let $0\le h_0\le h$ be the initial depth of the fluid, we may state that the work required to pump out the contents of the trough is given by:
$$W=\frac{\ell\rho}{h}\int_0^{h_0} (b-B)y^2+\left(s(B-b)+h(B-2b) \right)y+bh(h+s)\,dy$$
Applying the FTOC, we obtain:
$$W=\frac{\ell\rho}{h}\left[\frac{(b-B)}{3}y^3+\frac{s(B-b)+h(B-2b)}{2}y^2+bh(h+s)y \right]_0^{h_0}$$
$$W=\frac{\ell\rho}{6h}\left(2(b-B)h_0^3+3\left(s(B-b)+h(B-2b) \right)h_0^2+6bh(h+s)h_0 \right)$$
In the given problem, we are told the trough is initially full, i.e. $h_0=h$, so for such a case the above formula becomes:
$$W=\frac{\ell\rho}{6}\left(2(b-B)h^2+3\left(s(B-b)+h(B-2b) \right)h+6bh(h+s) \right)$$
Expanding and collecting like terms, we obtain:
$$W=\frac{\ell\rho h}{6}\left(b(2h+3s)+B(h+3s) \right)$$
In the given problem, we are told we need only to pump the fluid to the top of the tank, i.e. $s=0$, so for such a case the above formula becomes:
$$W=\frac{\ell\rho h^2}{6}(2b+B)$$
Now, the data we are given for this problem is:
$$\ell=15\text{ m},\,\rho=\frac{1000\text{ kg}}{\text{m}^3}\cdot9.8\frac{\text{m}}{\text{s^2}}=9800\frac{\text{N}}{\text{m}^3},\,h=5\text{ m},\,b=2.5\text{ m},\,B=5\text{ m}$$
Plugging in this data, we find:
$$W=\frac{15\cdot9800\cdot5^2}{6}(2\cdot2.5+5)\text{ J}=6.125\text{ MJ}$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
