Calculating work with kinematics and dynamics
In summary: Therefore, fnet=0 and fn=fg. In summary, a 62 kg person in an elevator with a constant velocity of 4 m/s for 5 seconds experiences a normal force and force of gravity equal to their mass times acceleration. Using the equation W= F x Δd, the work done by the normal force is 12 kJ. If the elevator were moving down at the same speed and time, the work done by the normal force and force of gravity would remain the same.
jjesiee
the question is:
A 62 kg person in an elevator is moving up at a constant
speed of 4.0 m/s for 5.0 s. T / I C
(b) Calculate the work done by the normal force on the person.
(c) Calculate the work done by the force of gravity on the
person.
(d) How would your answers change if the elevator were
moving down at 4.0 m/s for 5.0 s?
W= F x Δd
and i think
Δd= (vf + vi/2)Δt
fg=m.g
for b) i did Δd= (vf + vi/2)Δt and got displacement which is 10 m and then i did fn=fg since fnet is 0 which means that they have the same force. and for that i got 607.6 N
p.s the answer in the back is 12 kJ which i don't get?
what if i told you that your equation for Δd is incorrect.
Δd = (vf +vi)/2 * Δt
see if that doesn't give you 12.1644 kJ
it wouldn't matter though cause vi= 0 (i think)
The initial velocity is not vi=0, however, vf=vi since the velocity is constant.
you sure? I've never heard of that before but thanks.
Technically, if vi=0, then during that time frame there was indeed an acceleration and the velocity is then not constant. However, by equating vi=vf we are merely indication that the velocity remains constant and a=0.
thank you sandy.bridge
vi does not equal 0
the statement says constant velocity of 4 m/s
thus vi = vf = 4 m/s
the elevator is accelerating so fnet can not equal to 0.
fn +fg=ma
fn +fg=ma
No, it is given during that particular 5 second time interval that the elevator is not accelertaing, that is, it is given that it is moving at constant speed.
Related to Calculating work with kinematics and dynamics
What is the formula for calculating work with kinematics and dynamics?
The formula for calculating work is W = F * d, where W is work, F is the force applied, and d is the distance over which the force is applied.
How do kinematics and dynamics play a role in calculating work?
Kinematics and dynamics are both branches of physics that deal with the motion of objects. Kinematics focuses on the description of motion, while dynamics focuses on the causes of motion. In order to calculate work, we need to understand the motion of an object and the forces acting on it, making both kinematics and dynamics important in this calculation.
What units are used to measure work?
The SI unit for work is the joule (J). Other commonly used units for work include foot-pounds (ft-lb) and calories (cal).
Can work be negative?
Yes, work can be negative. This occurs when the force applied is in the opposite direction of the displacement. In this case, the work done by the force is considered to be negative.
How is work related to energy?
Work and energy are closely related concepts. Work is the transfer of energy from one object to another, or the change in energy of an object. In other words, work is a means of transferring energy, and the amount of work done is equal to the change in energy of the object.
