Calculation of (a,b,c,d) for Given Large Factorial Number
  • MHB
  • Thread starter juantheron
  • Tags
    Calculation
In summary, the conversation discusses how to calculate the values of $(a,b,c,d)$ using the given equation and the divisibility by $9$ and $11$ rules. The approach suggested is to first find $a$ and $b$, and then use the divisibility rules to find $c$ and $d$. This can be done by eliminating the seven zeros at the end of $34!$ and using the divisibility test for $2^7$ to find $a$ and $b$, and then using the divisibility test for $9$ and $11$ to find $c$ and $d$. The final values of $(a,b,c,d)$ are $(5,2,0,3)$.
juantheron
247
Given $34!=295232799cd9604140847618609643ab0000000.$ Then $(a,b,c,d)$ is
I did not understand how can i calculate $(c,d)$, If I get $(c,d)$,
Then i will easily get $(a,b)$ using divisibility by $9$ and $11$
Mathematics news on Phys.org
Re: calculation of (a,b,c,d)
Would it be better to tackle it the other way round, finding $a$ and $b$ first and then using your clever $9$-and-$11$ idea to get $c$ and $d$?
One way to find $a$ and $b$ would be to start with the prime factorisation $34! = 2^{32}\cdot 3^{15}\cdot 5^7\cdot 7^4\cdot 11^3\cdot 13^2\cdot 17^2\cdot 19\cdot 23\cdot 29\cdot 31$, then divide by $2^7\cdot 5^7$ to eliminate the seven $0$s at the end of $34!$. That leaves you with $2^{25}\cdot 3^{15} \cdot 7^4\cdot 11^3\cdot 13^2\cdot 17^2\cdot 19\cdot 23\cdot 29\cdot 31$. You could find the last two digits of that by explicitly multiplying out that product, reducing$\mod{100}$ as you go – laborious but just about doable with a calculator.
Thanks opalg got it.
Here $34!$ contain $2^{32}$ and $5^7$. So $2^{25}$ remaining and $2^{7}\cdot 5^7 = (10)^7$ form $7$ zeros at the end.
So $34! = 295232799cd9604140809643ab \times 10^7$ now after deleting $7$ zero,s ,
So we get $34! = 295232799cd9604140809643ab$
Now we use divisibility test for last $7$ digits using $2^7$.
Here $(a,b)\in \{0,1,2,3,4,5,6,7,8,9\}$
So Divisiblilty by $2^2$, we get
$00,04,08,12,16,20,24,28,32,36,40,44,48,52,56,60,64,68,72,76,80,84,88,92,96$ ect
So Divisibility by $2^3$
$304,312,320,328,336,344,352,368,376,384$
In a similar manner
at last when divisible by $2^{7},$ we get $ab = 52$
Now Using $9$ and $11$ divisibility test, we get $c$ and $d$
So $(a,b,c,d) = (5,2,0,3)$
Thanks opalg.
FAQ: Calculation of (a,b,c,d) for Given Large Factorial Number
What is the purpose of calculating (a,b,c,d)?
The calculation of (a,b,c,d) is used to solve equations or problems that involve multiple variables. It allows for the determination of the values of these variables in order to find a solution.
What are the common methods used for calculating (a,b,c,d)?
The most common methods for calculating (a,b,c,d) include algebraic manipulation, substitution, graphing, and using mathematical formulas or equations specific to the problem.
How do I know which values to assign for a, b, c, and d in the calculation?
The values of a, b, c, and d are dependent on the specific problem or equation being solved. It is important to carefully read and understand the problem in order to determine the appropriate values to use in the calculation.
Can the order of a, b, c, and d affect the outcome of the calculation?
Yes, the order of a, b, c, and d can have an impact on the outcome of the calculation. In some cases, changing the order of the variables may result in a different solution or no solution at all.
Are there any common mistakes to avoid when calculating (a,b,c,d)?
One common mistake to avoid is not carefully checking the arithmetic when performing the calculation. It is also important to double check the values used for a, b, c, and d to ensure they are correct and appropriate for the problem.
