Calculation of an amplitude using the Grassmannian approach (amplituhedron)
In summary, the Grassmannian approach is a mathematical framework used in particle physics to calculate amplitudes. It uses a geometric structure called the Grassmannian to represent all possible interactions between particles. An amplituhedron, a higher-dimensional shape, is used to simplify and streamline the calculation process. This approach eliminates the need for complicated Feynman diagrams and integrals, resulting in a more elegant and efficient method. There are also potential advantages such as handling higher numbers of particles and providing new insights into particle interactions. However, as it is still a developing field of research, there may be limitations or challenges in its application to different systems. Further research is needed for a better understanding of its scope and limitations.
kdv
348
In the following review paper on scattering amplitudes, by Elvang and Huang:
https://arxiv.org/abs/1308.1697
they calculate the amplitude for 6 particles with half of positive helicity and half of negative helicity in section 9.3.2. Their matrix C (a point in the relevant Grassmannian) is parametrized as in Eq. 9.35.
They then use a contour of integration giving three contributions (after applying the residue theorem). The three contributions are given in 9.45 and 9.46.
Now, Arkani-Hamed et al do the same calculation using a slightly different approach, see https://arxiv.org/pdf/1212.5605.pdf. They use plabic graphs to represent different contributions to an amplitude. The plabic graphs corresponding to the amplitude of interest are given in Figure 16.6, with the total amplitude given just below, in Eq. 16.7.
Continuing with Arkani-Hamed et al, the contribution from *one* of these three plabic graphs is calculated (without providing much details) in Eqs 8.6 and 8.7. They give now the matrix C once the integral is done. Now, they don't show it but they do mention (just below 8.7) that they use a parametrization "making the residue about the pole (123)=0 easy to read off" (here, (123) is the minor involving the first three columns of C). So the matrix C they give in (8.6) is the result obtained after doing the integral.
Now I can ask my question: How are the two approaches related? In the case of Elvang and Huang, they have a single integral which generates all three terms in the full amplitude. In the case of Arkani-Hamed et al, they have three plabic graphs that each apparently contribute a single term in the amplitude.
So the initial integral used by Elvang and Huang must differ from the integral used by Arkani-Hamed et al. It is difficult to see because of the different notation used and the different ways of writing the delta functions. I am hoping that someone who knows this material will be able to point out how the two approaches differ, at a basic level. A related question is: then it does not seem that one can associate to the intergal a plabic graph to the approach followed by Elvang and Huang since there single integral gives all three plabic graphs. Is that right?
Thanks in advance
Likes atyy
Thank you for bringing up this interesting question. The two approaches, as described in the papers by Elvang and Huang and Arkani-Hamed et al, are indeed different but are related in the sense that they both use different strategies to calculate the same physical quantity.
In the paper by Elvang and Huang, they use a contour integral approach to calculate the amplitude for 6 particles with half of positive helicity and half of negative helicity. They parametrize their matrix C, which is a point in the relevant Grassmannian, and use a contour of integration to get three contributions (after applying the residue theorem). These three contributions correspond to the three terms in the full amplitude.
On the other hand, Arkani-Hamed et al use a different approach, where they use plabic graphs to represent different contributions to the amplitude. The plabic graphs corresponding to the amplitude of interest are given in Figure 16.6, with the total amplitude given just below, in Eq. 16.7. They then calculate the contribution from one of these three plabic graphs using a different parametrization of the matrix C. This parametrization makes the residue about the pole (123)=0 easy to read off, as mentioned in the paper.
So, in summary, the two approaches are different in terms of the parametrization of the matrix C and the method of integration, but they both lead to the same physical result. To answer your related question, yes, it is not possible to associate a plabic graph to the approach followed by Elvang and Huang, as their single integral gives all three plabic graphs.
I hope this helps to clarify the relationship between the two approaches. Thank you for your interest in this research and for your question.
FAQ: Calculation of an amplitude using the Grassmannian approach (amplituhedron)
What is the Grassmannian approach to calculating amplitudes?
The Grassmannian approach to calculating amplitudes involves representing scattering amplitudes in terms of Grassmannian manifolds, which are spaces parameterized by matrices subject to certain constraints. This method provides a geometric interpretation of the scattering processes and simplifies the calculation of amplitudes by leveraging the combinatorial and algebraic properties of these manifolds.
What is the amplituhedron, and how does it relate to the Grassmannian approach?
The amplituhedron is a geometric object that generalizes the concept of the Grassmannian and is used to describe scattering amplitudes in a more intuitive and visual manner. In the context of the Grassmannian approach, the amplituhedron provides a way to understand the space of all possible scattering amplitudes as a single, unified geometric entity, where the volume of the amplituhedron corresponds to the amplitude itself.
How does the Grassmannian approach simplify the calculation of scattering amplitudes?
The Grassmannian approach simplifies the calculation of scattering amplitudes by reducing the problem to finding certain geometric objects within the Grassmannian manifold. This method bypasses the need for complex Feynman diagrams and instead uses algebraic and combinatorial techniques to directly compute the desired amplitudes, often resulting in more compact and elegant expressions.
What are the key mathematical tools used in the Grassmannian approach?
The key mathematical tools used in the Grassmannian approach include Grassmannian manifolds, Plücker coordinates, and various algebraic geometry techniques. Additionally, concepts from combinatorics, such as on-shell diagrams and positroids, play a crucial role in organizing and simplifying the calculations. The amplituhedron itself is studied using tools from convex geometry and differential geometry.
Can the Grassmannian approach be applied to all types of particle interactions?
While the Grassmannian approach and the amplituhedron have been most successfully applied to certain classes of particle interactions, particularly in planar N=4 supersymmetric Yang-Mills theory, researchers are actively working on extending these methods to more general cases. The approach shows promise for a wide range of interactions, but its full applicability to all types of particle interactions is still an area of ongoing research.
