Calculation of average damage using analytical methods
  • A
  • Thread starter someoneSomewhere
  • Tags
    Probability
In summary, the calculation of average damage using analytical methods involves the application of mathematical models and statistical techniques to assess and quantify damage levels in various contexts, such as engineering, insurance, and disaster management. These methods enable the estimation of expected damage based on factors like historical data, risk assessments, and operational conditions, providing valuable insights for decision-making and resource allocation. Analytical approaches often include probabilistic models, simulations, and sensitivity analyses to enhance accuracy and reliability in damage assessments.
someoneSomewhere
TL;DR Summary
I have a task, the conditions of which you can read below. I understand how to solve it by approximating the value, but I would like to know how I can derive an equation (and is it even possible?), which can calculate the exact value.
Hello! A friend shared a problem he recently solved. It goes as follows:
Given:
Each dagger strike deals either normal damage = 20 or critical damage = 80.
After each strike, the probability of dealing normal and critical damage changes (initial probabilities are 90% and 10% respectively). The probability changes according to the following two conditions:
1. If the previous strike dealt normal damage, the probability of dealing normal damage decreases by 3%, and the probability of dealing critical damage increases by 3%.
2. If the previous strike dealt critical damage, the probability of dealing normal damage becomes 90%, and the probability of dealing critical damage becomes 10%.
Find:
The average damage for n strikes.
How to solve this problem through approximation is obvious to me. Here's the Python code:
The answer is approximately 31.5.
However, I am interested in the possibility of solving this problem analytically. That is, to write some equation that can be calculated for n values and get not an approximation, but an exact answer. Is this possible? I am weak in mathematical statistics and cannot imagine how to do this. You can simply point out some vectors of study that I need to explore to derive the equation myself, but I would be more grateful if you could derive this equation.
I can't derive an analytic expression. It is possible to write a recursive equation to compute the probability of critical damage after n rounds.
The process is a markov chain with 31 states.
State 0 is the starting state with critical hit probability 0.1. State 30 is the state with critical probability 1.
From state m you''ll go back to state 0 after a critical hit, and to state m+1 otherwise.
let prob(m,n) be the probability to be in state m after n rounds.
let crit(m) = 0.1 + 0.03m.
After 0 rounds, you'll be in the starting state so:
prob(0,0) = 1, and prob(m,0) = 0 if m <> 0;
prob(0,n) will be the sum of prob (m,n-1) * crit(m) (for all states m)
(you'll be in the starting state, if you got a critical hit in the round before)
prob(m,n) if m<>0 will be prob(m-1,n) * (1 - crit (m-1))
you'll be in state m, if you were in state m-1 on the round before and you dit not get a critical hit.
You can than sum prob(m, n) * crit(m) over all rounds to get the average damage.
Python:
from functools import cache
def crit(i):
    return 0.1 + 0.03 * i
@cache
def prob(m,n):
        if n == 0:
            if m == 0:
                return 1
            return 0
        if m == 0:
            probsum = 0
            for i in range (0,31):
                probsum += prob(i, n-1) * crit(i)
            return probsum
        return prob(m-1,n-1) * ( 1 - crit(m-1) )
crit_dam = 80
norm_dam = 20
rounds = 10
total_damage = 0
for n in range(0, rounds):
    for m in range(0,31):
        total_damage += prob(m, n)  * (crit(m) * crit_dam   +  (1-crit(m)) * norm_dam)
print (total_damage /rounds)
Your python program computes the average damage after 10000 stabs, and not after 10 stabs.
average damage after 1 stab is 26, after 10 30.103... and it seems to converge to about 31.471 if the rounds go to infinity.
This recursive program is horribly inefficient without using the @cache decorator from functools, and you'll probably never get an answer for n=20. If you want to implement it an another language you may have to make a 2 dimensional table for prob(m,n) yourself.
Likes someoneSomewhere
Python:
def crit(i):
@cache
def prob(m,n):
        if n == 0:
            if m == 0:
                return 1
            return 0
        if m == 0:
            probsum = 0
            return probsum
crit_dam = 80
norm_dam = 20
rounds = 10
total_damage = 0
Thank you very much for your answer. I think it more than satisfies my interest!
Yes you can calculate this analytically: the equation would involve some quite complicated summations which would be difficult to write out correctly. It is easier to write code to do it (see below), or to work it out using a spreadsheet.
Just basic probability trees and a LOT of practice. Even with practice it is easy to make a mistake and I would always verify any result by Monte Carlo methods anyway.
"Approximation" is not the right term here, we call the method you used "Monte Carlo simulation" or just "simulation".
Here is some code to calculate the answer and the results.
Python:
DAMAGE = 20
DAMAGE_CRIT = 80
P_CRIT_INITIAL = 0.1
P_CRIT_INCREMENT = 0.03
# Consecutive number of non-critical hits
k = 0
pLengths = []
pContinuing = 1
pCrit = P_CRIT_INITIAL
weightedSumOfLengths = 0
# Work around missing do...while in Python.
while True:
    # Calculate the probability of the sequence ending
    # here with a crit.
    pEnding = pContinuing * pCrit
    pContinuing -= pEnding
    pLengths.append(pEnding)
    # Accumulate the weighted sum of lengths.
    weightedSumOfLengths += (k + 1) * pEnding
    if pCrit >= 1: break
    # Mitigate truncation errors.
    pCrit = round(pCrit + P_CRIT_INCREMENT, 15)
    k += 1
nonCrits = 0
weightedSum = 0
totalProbability = 0
formatter = ' {:3} {:10.4g} {:10.6f}'
print('Hits Probability   Damage')
# Iterate over all possible sequence lengths.
for pLength in pLengths:
    # The probability that a hit is within a sequence of length nonCrits + 1.
    pInSequenceOfLength = pLength * (nonCrits + 1) / weightedSumOfLengths
    # Sum the probabilities for checking later.
    totalProbability += pInSequenceOfLength
    damagePerHit = (nonCrits * DAMAGE + DAMAGE_CRIT) / (nonCrits + 1)
    # Aggregate the weighted damage
    weightedSum += damagePerHit * pInSequenceOfLength
    nonCrits += 1
    print(formatter.format(nonCrits, pInSequenceOfLength, weightedSum))
print('Total probability (should be 1)', sum(pLengths), totalProbability)
print(weightedSum)
Results:
   1    0.01912   1.529585
   2    0.04474   3.766604
   3    0.07186   6.641000
   4    0.09557   9.986079
   5      0.112  13.571601
Total probability (should be 1) 0.9999999999999999 0.9999999999999998
31.471888847439825
FAQ: Calculation of average damage using analytical methods
What is the purpose of calculating average damage using analytical methods?
The purpose of calculating average damage using analytical methods is to quantify the expected damage outcome from a given set of conditions or scenarios. This helps in making informed decisions in fields such as game design, risk assessment, and engineering by providing a statistical measure of potential damage.
What are the common analytical methods used for calculating average damage?
Common analytical methods for calculating average damage include statistical analysis, Monte Carlo simulations, probabilistic models, and deterministic approaches. These methods use mathematical formulas and algorithms to estimate the average damage based on input variables and their distributions.
How do you handle variability in input parameters when calculating average damage?
Variability in input parameters is handled by incorporating probability distributions and statistical measures such as mean, variance, and standard deviation. Sensitivity analysis and Monte Carlo simulations are often used to account for and analyze the impact of variability on the average damage calculation.
What is the role of probability distributions in average damage calculations?
Probability distributions play a crucial role in average damage calculations by representing the likelihood of different outcomes for input parameters. They help in modeling the randomness and uncertainty inherent in real-world scenarios, allowing for more accurate and reliable average damage estimates.
Can you provide an example of calculating average damage using an analytical method?
Sure! Suppose you are calculating the average damage of a weapon in a game that deals between 10 to 20 damage points per hit. If each damage value within this range is equally likely, you can use the uniform distribution. The average damage (mean) can be calculated as the midpoint of the range: (10 + 20) / 2 = 15. Therefore, the average damage dealt by the weapon is 15 damage points per hit.
