MHB Calculation of concentration unit
The discussion revolves around calculating the correct concentration unit after adding a substance with a density of 1.020 kg/m3 at a rate of 800 µL/L to a sample. The substance is 60% w/w, leading to confusion about whether the final concentration should be expressed as 490 µg/L or 490 mg/L. Clarification is sought regarding the use of "u" to denote micro (µ) for microLitres and microGrams. The participants aim to determine the accurate concentration unit based on the provided data. The focus remains on resolving the concentration unit for the sample after the addition of the substance.
Lassy
I would like some help in working out the correct unit of concentration in the question below please.
I added a substance which has a density of 1.020 kg/m3 to a sample at a rate of 800 uL/ L of sample
The substance is also 60% w/w.
Will the final concentration in the sample be in 490 ug/L or 490 mg/L?
Thanks
Mathematics news on Phys.org
Thanks
Are you using "u" to represent the greek letter $\displaystyle \begin{align*} \mu \end{align*}$? If so, the units are "microLitres" and "microGrams", correct?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
