Calculation of Conduction Electron Population for Semi Conductor
In summary, the conversation discusses the formula for the density of electrons in the conduction band of a semiconductor and raises questions about its derivation. The Fermi level is approximated to lie at the center of the band gap in intrinsic semiconductors, but at non-zero temperatures it deviates due to differences in effective masses of holes and electrons. There may be an error in the exponential factor of the formula and integration by parts may have been applied. It is suggested to refer to solid state physics books for clearer derivations.
opuktun
28
Hi everyone,
From this website (link: http://hyperphysics.phy-astr.gsu.edu/HBASE/solids/fermi3.html#c1 ), we get the following expression:
[tex]Population Density of Conduction Electron = \int ^{\infty}_{Egap}N(E)d(E) = \frac{2^{5/2}(m \pi k T)^{3/2} exp (-E gap/2kT)}{h^3}[/tex]
My questions are based on the derivation given by the website as follow:-1. EF = Egap / 2
Is this a defined property of semiconductors?2. Is there an error in the following expression?
[tex]N(E)d(E) = \frac{8\sqrt{2} \pi m^{3/2}}{h^3} \sqrt{E-Egap}\ e^{-(E-Egap/2)}[/tex]
I mean originally it has kT in the power of exponential term. Is it mistakenly dropped?3. Is "integration by parts" applied on the following expression?
Somehow, I can't solve the integration.Thanks.
Formula for density of electrons in conduction band is a good approximation for a classical gas of carriers in intrinsic semiconductors. Only if electron gas is classical you can approximate Fermi - Dirac statistic with Boltzmann one and only if the semiconductor is intrinsic Fermi's level is in the middle of energy gap. In a more general
way Fermi's level depends on doping level, temperature and effective density of states.
Regarding point 2 the exponential factor must be dimensionless.
For more details it's better if you'll see on solid state physics's books. You' ll find clearer derivations than the one you found on the link you posted.
Matteo.
Just to address your first question: in intrinsic semiconductors (no impurities present), the Fermi level is often approximated as lying at the center of the band gap. It doesn't lie exactly at the center at non-zero temperatures, however, because the effective masses of holes and electrons are different. A more precise equation is
[tex]E_F=E_V+\frac{E_g}{2}+\frac{3}{4}k_B T \ln\frac{m^\star_h}{m^\star_e}[/tex]
Thanks Mapes for the explanation, I finally understood the r/s.
Thanks matteo. I'm gng to hit those books in my lib. :)
FAQ: Calculation of Conduction Electron Population for Semi Conductor
What is conduction electron population?
Conduction electron population refers to the number of electrons that are able to move freely and conduct electricity in a semiconductor material.
How is conduction electron population calculated?
The conduction electron population in a semiconductor can be calculated using the formula n = N * exp(-Eg/2kT), where n is the electron concentration, N is the total number of atoms in the semiconductor, Eg is the band gap energy, k is Boltzmann's constant, and T is the temperature in Kelvin.
What factors affect the conduction electron population in a semiconductor?
The conduction electron population in a semiconductor is affected by the material's band gap energy, temperature, and doping concentration. A higher band gap energy and lower temperature result in a lower electron concentration, while a higher doping concentration increases the electron concentration.
How does the conduction electron population impact the conductivity of a semiconductor?
The conduction electron population directly affects the conductivity of a semiconductor. A higher electron concentration leads to a higher conductivity, while a lower electron concentration results in a lower conductivity.
Why is the calculation of conduction electron population important in semiconductor research?
The calculation of conduction electron population is important in semiconductor research because it helps determine the material's electrical properties and how it can be used in various electronic devices. It also allows researchers to understand how different factors, such as temperature and doping, can affect the material's conductivity. This information is crucial in the design and development of new semiconductor technologies.
