Calculation of coolant tank size required to feed multiple grinding stations
To calculate the required size of a coolant tank for multiple grinding stations, the total flow rate of 12 taps at 20L per minute must be considered, totaling 240L per minute. The tank design includes a height of 500mm and necessitates separate sections for dirty and clean coolant to manage metal fines. It's essential to determine the volume of coolant lost per hour and how frequently the tank will need to be topped up. A magnetic filtration system is proposed to remove metal fines, and the diameter of a cylindrical tank must accommodate the total coolant volume when machines are shut down. Accurate measurements of the coolant volume in the system are crucial for determining the tank's capacity.
Rob365
TL;DR Summary
calculating size of coolant tank required.
I am trying to calculate the size of coolant tank required to feed multiple grinding stations.
I have a total of 12 taps all with flow rates of 20L per minute. All taps would operate at the same time.
The tank would be open topped and 500mm tall.
The tank also requires a dirty side and a clean side to remove metal fines.
Rob365 said:
TL;DR Summary: calculating size of coolant tank required.
What are you trying to achieve? Provide a diagram of the system, and design deliverables. “Size” is too vague.
What volume of coolant is lost per hour?
How often will you top up the tank?
Can you use magnets to remove the metal fines?
Can the abrasive material be recycled?
I am unsure of volume lost per hour the coolant levels would be checked weekly and topped up as needed, we are using a magnetic filtration system to remove the fines I am trying to figure out the diameter of a cylindrical tank i would require to be able to store all coolant when the machine is shut down.
Then the flow rate is not relevant. You need to know the volumetric capacity of all the machines, pumps and lines. You can measure that by measuring the volume of coolant in the system when the tank is not connected. Pump it all out into 200 litre drums.
Likes erobz, Lnewqban and Rob365
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
