roldy
- 237
- 2
Consider air in chemical equilibrium at 0.1 atm and T=4500 K. The chemical species are O2, O, N2, N (Ignore NO). Calculate the enthalpy and internal energy per unit mass of the mixture. Neglect electronic excitation in your calculations.
[tex]K_{p,O_2}=12.19 atm[/tex]
[tex]K_{p,N_2}=0.7899*10^{-4}atm[/tex]
[tex](\Delta H_f^o)_O=2.47*10^8 J/(kg*mol)[/tex]
[tex](\Delta H_f^o)_N=4.714*10^8 J/(kg*mol)[/tex]
[tex](\Theta_v)_{N_2}=3390 K[/tex]
[tex](\Theta_v)_{O_2}=2270 K[/tex]
[tex](1)h=\Sigma ^n_{i=1}c_ih_i + \Sigma ^n_{i=1}c_i \Delta h_{f_i}[/tex]
[tex]c_i=X_i\frac{\mu_i}{\mu}[/tex]
[tex]X_i=\frac{P_i}{P}[/tex]
[tex]R_{air}=\frac{R_u}{\mu_{air}}[/tex]
[tex]\mu_{air}=X_{O_2}*\mu_{O_2} + X_O*\mu_O + X_N*\mu_N + X_{N_2}*\mu_{N_2}[/tex]
Diatomic Gas:
[tex]h=e_{sens}+RT[/tex]
[tex]e_{sens}=3/2RT + RT +\frac{\frac{\Theta_v}{T}}{e^{\frac{\Theta_v}{T}}-1}RT[/tex]
Monatomic Gas:
[tex]h=5/2RT[/tex]
[tex]=e_{sens}=3/2RT[/tex]
The weight of each species is as follows:
[tex]O=16kg/(kg*mol)[/tex]
[tex]N=14kg(kg*mol)[/tex]
[tex]O_2=32kg/(kg*mol)[/tex]
[tex]N_2=28kg/(kg*mol)[/tex]
I then found what the gas constant was for each species with Ru=8314 J/(kg*K).
[tex]R_O=519.625[/tex]
[tex]R_N=593.8571[/tex]
[tex]R_{O_2}=259.8125[/tex]
[tex]R_{N_2}=296.9286[/tex]
I then calculated the sensible internal enthalpy for each species.
[tex]e_{sense,O}=3/2(519.625)(4500)=3.5075*10^6[/tex]
[tex]e_{sense,N}=3/2(593.8571)(4500)=4.0085*10^6[/tex]
[tex]e_{sense,O_2}=3/2(259.8125)(4500) + (259.8125)(4500) +\frac{\frac{2270}{4500}}{e^{\frac{2270}{4500}}-1}(259.8125)(4500)=3.8218*10^6[/tex]
[tex]e_{sense,N_2}=3/2(296.9286)(4500) + (296.9286)(4500) +\frac{\frac{3390}{4500}}{e^{\frac{3390}{4500}}-1}(296.9286)(4500)=4.2359*10^6[/tex]
Next the enthalpy per unit mass of each species was calculated.
[tex]h_O=5/2(519.625)(4500)=5.8458*10^6[/tex]
[tex]h_N=5/2(593.8571)(4500)=6.6809*10^6[/tex]
[tex]h_{O_2}=3.8218*10^6+259.8125(4500)=4.9910*10^6[/tex]
[tex]h_{N_2}=4.2359*10^6+296.9286(4500)=5.5721*10^6[/tex]
This is where I get stuck. I believe I use equation (1) in some way but I do not see how since I am not given the partial pressures to find [tex]c_i[/tex]. I'm not sure how the equilibrium constants work into this problem.
