Calculation of negative energy density in a Casimir cavity
In summary, the Casimir Effect is a relativistic, quantum force between charges and currents that has been used as evidence for the existence of vacuum fluctuations. However, the concept of vacuum fluctuations is still debated and it is argued that the Casimir Effect can be formulated and calculated without reference to zero point energies. The energy density between two Casimir plates can be calculated using the formula provided on the Wikipedia page, which is a function of the distance between the plates and is normalized relative to empty space. This resulting energy density is expected to be negative.
OrigamiNinja
24
Hello,
I would like to know how to calculate the negative energy density in the region between two Casimir plates, given a distance between two parallel plates.
Thanks, much appreciated!
OrigamiNinja said:
Hello,
It is far from certain that such a thing exists.
This is a recent paper on the subject
Proof that Casimir force does not originate from vacuum energy
Hrvoje Nikolic
https://arxiv.org/abs/1605.04143v3
That paper is definitely a minority opinion. Also, I believe that it is disproven due to the fact that the casimir effect can be reversed:
http://www.nature.com/nature/journal/v457/n7226/full/nature07610.html
If the Casimir force was caused by van der walls forces, I do not believe it would be reversible experimentally in this way; this method of reversing the Casimir force using a medium of permittivity constants between that of the two plates. I'm pretty sure that would not work if the Casimir force was due to van der wall forces.
You can ask him ask him if you wish. I'm not really interested for now; I'm mostly just here for the calculation.
I'm sure there many learned papers on the subject. Did you know about the paper in your second post before your first post ?
I was aware of the paper that I referred you to before the conversation, but I was not aware of the paper you referred me to. But as far as I know, it's been pretty well established that the Casimir force is due to vacuum fluctuations. I'm not sure how the Croatian physicist came to his conclusions, but if they were right, I don't think you could reverse the Casimir force experimentally the way they have.
well I'll amend that; I was aware of the research where the Casimir force was reversed and that it was done by physicists from a group at Harvard, not the specific paper itself per se. Knowing that this had been done is how I found the paper.
As far as I can discern the idea of vacuum fluctuations is either completely wrong or a misnomer for field fluctuations. You will find articles and posts in this forum on these subjects.
Here's another reference
The Casimir Effect and the Quantum Vacuum
R. L. Jaffe
(Submitted on 21 Mar 2005)
In discussions of the cosmological constant, the Casimir effect is often invoked as decisive evidence that the zero point energies of quantum fields are "real''. On the contrary, Casimir effects can be formulated and Casimir forces can be computed without reference to zero point energies. They are relativistic, quantum forces between charges and currents. The Casimir force (per unit area) between parallel plates vanishes as \alpha, the fine structure constant, goes to zero, and the standard result, which appears to be independent of \alpha, corresponds to the \alpha\to\infty limit.
https://arxiv.org/abs/hep-th/0503158v1
Likes Jilang
Look, there are other effects of vacuum fluctuations, not just the Casimir Effect. Hawking radiation for example. It isn't a very contentious issue in the field. It's basically accepted. I'm not really interested in arguing. If you don't want to believe in vacuum fluctuations, fine. I'm just here for the calculations I mentioned in the first post. Thanks.
one edit, here is an article (the paper link is at the bottom of the article) about an experiment where a virtual photon was successfully extracted from the vacuum:
https://phys.org/news/2011-11-scientists-vacuum.html
The Wiki article shows some calculations which could be what you're looking for. Treat with caution.
https://en.wikipedia.org/wiki/Casimir_effect
I had a quick read of the 'virtual photon' paper and as usual there is no vacuum in the experiment. The whole experimental volume is flooded with fields and the matter of the equipment. If they have detected something, they cannot claim it came from nothing.
ok, thanks
I am just writing a paper where I will explain in detail all these conceptual subtleties on Casimir effect. In short, to claim that Casimir effect is or is not a consequence of vacuum energy, one first needs to explain what one means by the word "vacuum". In particular, Casimir vacuum is not a state with a zero number of photons. It is a state with a zero number of certain quasiparticles which are mixtures of photons and polarization quanta.
Likes Simon Bridge
This was pointed out to the OP six years ago. While it's true that he has a misunderstanding, it's also apparent that he's not about to give it up.
Likes weirdoguy, Mentz114 and Demystifier
The wikipedia page had a formula for finding the force between two plates as a function of distance, but not one for energy density. Rather than trying to derive it myself I was hoping someone more experienced with it could provide a correct formula for this. Demystifier, this sounds like it could be your territory?
I'm hoping for a formula for energy density, as a function of plate distance, which should be normalized relative to empty space. So the resulting energy density, if I understand, should be negative.
See Itzykson and Zuber, Quantun Field Theory (1986) McGraw-Hill, pages 138 ff. Enjoy.
Ok, there is ambiguity in this area.
A wikipedia article on Van der Walls suggests that each originate from vacuum energy:
"It can be shown that van der Waals forces are of the same origin as the Casimir effect, arising from quantum interactions with the zero-point field.[2]"
https://en.wikipedia.org/wiki/Van_der_Waals_force
I've found this paper, which may help shed some light on it. I can't read all of it now I have something else to do, but I'm going to post it anyway, because it looks promising.
https://arxiv.org/pdf/quant-ph/0302072.pdf
My current interpretation is the Van Der Walls force is actually two things; 1) particle interaction via intermolecular forces such as London forces, and 2) effects from virtual modes (aka virtual particles, aka zero-point energy, aka vacuum energy, etc.) which some people appear to be very skeptical about, however, none the less these appear to be accepted in the literature at a high level, and also appear to explain various physical phenomena.
So despite the fact that all of these interactions occur on the scale of microns or less, the distance between surfaces, as well as the chemical composition of the surfaces appears to play a role in anticipating which of these forces dominates. What I am currently calling the 'Casimir force' essentially exclusively is due to actions of virtual modes; the van der walls force, I think, involves this also, but also can include other things, and is more dominant at very small distances, like nanometers.
Wait a couple of days to finish my paper, after which, I hope, no conceptual questions should remain.
If you know the force ##F(y)##, the you also know the energy ##E=-\int dy\, F(y)##. The energy density is then just the energy divided by volume (between the plates).
There is only one effect, which can be described mathematically in two different ways. The vacuum-energy description is technically simpler, but lacks a full microscopic description. In vacuum-energy description for perfect conductors, one assumes that electric field vanishes at the plates, which sets up the boundary conditions. But why does electric field vanish in a perfect conductor? That's because the movable charges in the conductor rearrange themselves, to cancel any external electric field. But rearrangement means that charges are polarized, and polarization of charges gives rise to van der Waals forces. So it is really the van der Waals force that causes boundary conditions. Since boundary conditions cause the Casimir force (for otherwise the vacuum energy is a constant which does not depend on the distance between the plates, in which case it does not give rise to a force), it follows that that van der Walls force causes the Casimir force. Or more schematically,
charge-field interactions -> van der Waals force -> boundary conditions -> Casimir force
Likes Jilang
Demystifier said:
The paper is finished now:
https://arxiv.org/abs/1702.03291
"In physics, the word “vacuum” has many different meanings. It can mean a state without any particles whatsoever, or a state without only one kind of particles such as photons, or a state annihilated by some lowering operators, or a local minimum of a classical potential, or the state with the lowest possible energy. Of course, all these notions of “vacuum” are closely related, but the point is that they are not strictly identical."
You also forgot Higgs, cc, 1/m_pl, string 10^1000, lqg space fluctution.. etc
What is photon vacuum, I get this as first hit when I google
https://en.wikipedia.org/wiki/Virtual_particle
back to square one.:eek:
Related to Calculation of negative energy density in a Casimir cavity
1. How is negative energy density calculated in a Casimir cavity?
The negative energy density in a Casimir cavity is calculated by taking the difference between the energy density inside the cavity and the energy density outside the cavity. This is known as the Casimir effect and is caused by the presence of virtual particles in the vacuum.
2. What is the significance of negative energy density in a Casimir cavity?
The negative energy density in a Casimir cavity is significant because it can lead to attractive forces between the two plates of the cavity. This effect has been observed in experiments and has potential applications in nanotechnology and quantum computing.
3. How is the negative energy density affected by the size of the Casimir cavity?
The negative energy density in a Casimir cavity is inversely proportional to the size of the cavity. This means that as the distance between the plates increases, the negative energy density decreases. However, it does not completely disappear even at very large distances.
4. Can negative energy density be used as a source of energy?
No, negative energy density cannot be used as a source of energy. It is a property of the vacuum and cannot be extracted or harnessed for practical purposes.
5. Are there any potential drawbacks or limitations to the calculation of negative energy density in a Casimir cavity?
One potential limitation is that the Casimir effect is only observed at very small distances, on the order of nanometers. This makes it difficult to study and apply in practical settings. Additionally, there may be other factors that contribute to the observed negative energy density, making it challenging to isolate and accurately calculate. Further research is needed to fully understand and utilize this phenomenon.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
