Calculation of round slots on the rotor for a squirrel cage asynchronous motor
  • Thread starter Thread starter SenyaUw
    Cage Rotor
SenyaUw
TL;DR Summary
Good afternoon, I started calculating the asynchronous motor with 2P=2 Zs=24, Zr=28. I want to use round-shaped closed-type slots for copper bars. The question is whether there is any method for calculating such round grooves of a closed type, before that I used rectangular or trapezoidal all the time. There are also some recommendations for choosing the height to which the rods should be sunk. Rotation speed 50000, rotor diameter 55 mm.Thank you in advance
Rounds bars are not well suited for higher torque applications. Burying them can decrease torque pulsations and noise, while sacrificing leakage induction and breakdown torque.
You can find a somewhat more detailed treatment of them in Boldea, Nasar - The induction machine handbook.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
