spaghetti3451
- 1,344
- 34
Consider the following extract taken from page 60 of Matthew Schwartz's 'Introduction to Quantum Field Theory':We usually calculate ##S##-matrix elements perturbatively. In a free theory, where there are no interactions, the ##S##-matrix is simply the identity matrix ##\mathbb{1}##. We can therefore write ##S=\mathbb{1}+i\mathcal{T}##, where ##\mathcal{T}## is called the transfer matrix and describes deviations from the free theory. Since the ##S##-matrix should vanish unless the initial and final states have the same total ##4##-momentum, it is helpful to factor an overall momentum-conserving ##\delta##-function: ##\mathcal{T}=(2\pi)^{4}\delta^{4}(\sum p)\mathcal{M}##. Here, ##\delta^{4}(\sum p)## is shorthand for ##\delta^{4}(\sum p^{\mu}_{i} - \sum p^{\mu}_{f})##, where ##p^{\mu}_{i}## are the initial particles' momenta and ##p^{\mu}_{f}## are the final particles' momenta. In this way, we can focus on computing the non-trivial part of the ##S##-matrix, ##\mathcal{M}##. In quantum field theory, "matrix elements" usually means ##\langle f|\mathcal{M}|i\rangle##. Thus we have
$$\langle f|S-\mathbb{1}|i\rangle = i(2\pi)^{4}\delta^{4}(\sum p)\langle f|\mathcal{M}|i\rangle.$$
Now, it might seem worrisome at first that we need to take the square of a quantity with a ##\delta##-function. However, this is actually simple to deal with. When integrated over, one of the delta functions in the square is sufficient to enforce the desired condition; the remaining ##\delta##-function will always be non-zero and formally infinite, but with our finite time and volume will give ##\delta^{4}(0)=\frac{TV}{(2\pi)^{4}}##. For ##|f\rangle \neq |i\rangle## (the case ##|f\rangle = |i\rangle##, for which nothing happens, is special),
$$|\langle f|S|i\rangle |^{2}=\delta^{4}(0)\delta^{4}(\sum p)(2\pi)^{8}|\langle f|\mathcal{M}|i\rangle|^{2} = \delta^{4}(\sum p)TV(2\pi)^{4}|\mathcal{M}|^{2},$$
where ##| \mathcal{M} |^{2} \equiv | \langle f | \mathcal{M} | i \rangle |^{2}.##Why can we factor out the momentum-conserving delta function? Are we integrating the transfer matrix ##\mathcal{T}## over the some integration variable so that the delta function helps to conserve the ##4##-momentum?
