Calculation of the adjusted mean
In summary, the probability that A is the fastest runner is 0.5. The probability that runners C and D (in any order of arrangement) are the slowest runner is 1/4.
thereddevils
438
Four runners A,B,C, and D ran 100m each. The time taken, in seconds by each runner can be considered as independent observation from a normal distribution with mean 14 and SD 0.2 . A runner E ran 400 m. THe time taken by E can be considered as an observation from a normal distribution with mean 58 and SD 1.0 independent of the times taken by the other runners. For the four runners A,B,C and D , find the probabiltiy that A is the fastest runner. Find also the probability that runners C and D (in any order of arrangement) are the slowest runner.
Maybe some hints to get me started on both parts of the questions.
Does your first question mean "What is the probability A is the fastest runner among A, B, C, and D?" (with runner E not coming into play at all?) If so,
I know you typed their distributions, but what does the information tell you about the distributions for A, B, C, and D?
I thought of this:
P(A-B>0) x P(A-C>0) x P(A-D>0)
and P(A-B>0)=P(A-C>0)=P(A-D>0)
but the problem is the calculation of the adjusted mean and SD. Take A-B for example,
E(A-B)=E(A)-E(B)=0
so P(A-B>0)=P(Z>0)=0.5 ?
and the required probability would be (0.5)^3 ?
Not quite: think this way: A, B, C, D are identically distributed: if you have four identical items, what is the probability of selecting A (as the smallest)?
oops maybe i have been thinking too much. The answer is simply 1/4. Am i right?
:). Good
FAQ: Calculation of the adjusted mean
What is the purpose of calculating the adjusted mean?
The adjusted mean is used to account for any potential confounding factors that may affect the overall mean of a set of data. It allows for a more accurate representation of the central tendency of the data by removing the impact of the confounders.
How is the adjusted mean calculated?
The adjusted mean is calculated by first determining the mean of the data. Then, the impact of the confounding factor is determined by subtracting the mean of the control group from the mean of the experimental group. This difference is then added to the overall mean to get the adjusted mean.
When should the adjusted mean be used?
The adjusted mean should be used when there are potential confounding factors that may affect the overall mean of the data. It is especially useful in experiments where there are multiple treatment groups and the impact of each treatment needs to be isolated.
Can the adjusted mean be negative?
Yes, the adjusted mean can be negative if the confounding factor has a larger impact on the experimental group than the control group. This means that the experimental group may have a lower mean than the control group after the confounding factor is taken into account.
Are there any limitations to using the adjusted mean?
One limitation of the adjusted mean is that it assumes that the confounding factor is evenly distributed among the groups being compared. If this is not the case, the adjusted mean may not accurately reflect the true central tendency of the data. Additionally, the adjusted mean may not be appropriate for certain types of data, such as categorical or ordinal data.
12K
