Calculation of torque for motion control camera arm
In summary, calculating torque for a motion control camera arm is important for determining the force and rotational motion needed for smooth and precise movements of the arm during filming. This is done by multiplying the force applied by the distance from the pivot point. The torque required is affected by factors such as weight, length, and speed of movement, and can be used to improve performance by making necessary adjustments. Safety considerations include not exceeding the maximum torque limit and regularly maintaining the equipment.
alevesque
Hi,
First post here, but I've been reading the forums for a while getting answers for various projects.
I am currently working on a lightweight motion control camera arm (kind of a small jib arm, but with servo actuators). I've researched a lot to figure out what force I would need in order to move things smoothly... I would love if someone could have a look at my calculation and see if I forgot something.
Here's a rough CAD of the arm:
http://www.newreel.ca/arm.jpg
At the pivot point, the load is almost perfectly balanced (it will hold any position without trying to move, and requires very little effort to move around). The whole arm (including camera/lens and counter-weight) is about 6KG. Dual ball-bearings on all axis, so friction is minimal.
In order to calculate the torque required to move (or stop the movement) of the arm, I've used the expression used to get the moment of inertia of a cylinder about its central diameter axis;
I = (MR2)/4 + (ML2)/12
The arm is 1.5m long (110cm on the long end, and 40cm back for the counterweigth), and about 20cm in diameter (a bit less, but since it's not quite a cylinder I figured it would be close). As I said, it's 6kg, so:
I = (6*0.12)/4 + (6*1.52)/12
Which gives me 1.14 kg m2
I want the arm to cover 90° in 0.75 sec, so I'm asking for a 2.0944 rad/s acceleration, right?
If this is right, then the required torque would be:
T = I*A2;
T = 1.14*2.09442;
T = 5Nm = 708.14oz/in.
The servo I plan on using can deliver 580oz/in at max power, and is driving a timing belt/pulley with a 2.16:1 ratio... In theory, that would give me over 1,200oz/in of torque which would cover (hopefully) for the friction induced at the timing belt/pulley and bearings... Does all that seem to make sense? Am I too close? I'm not sure about the cylinder calculation, since the pivot point is offset, but since the counterweight is moving the center of gravity, I thought it would be equivalent... I'm also not sure about the acceleration calculation, as 2.0944 rad/s is the average, but it has to accelerate and then stop at 90°, so it will be moving quite faster midway - do I need to take that into account, or the acceleration is effectively calculated by doing the average?
Thanks for looking into it, any pointers and/or suggestion are much appreciated.
-A
lex
Hi Alex,
First of all, great job on your research and calculations so far! It seems like you have a good understanding of the mechanics involved in your project.
Based on your calculations, it does seem like you have enough torque to move the arm smoothly. However, there are a few things to consider:
1. In your calculation for torque, you have used the moment of inertia for a cylinder, but your arm is not a perfect cylinder. It has a different shape and weight distribution, so the moment of inertia might be slightly different. To get a more accurate calculation, you can use the parallel axis theorem, which takes into account the offset pivot point and the weight distribution of your arm.
2. The acceleration calculation you have done is for the average acceleration. As you mentioned, the arm will need to accelerate and then decelerate to reach the 90° angle in 0.75 seconds. This means that the actual acceleration will be higher than 2.0944 rad/s at some points during the movement. To get a more accurate calculation, you can use the maximum acceleration, which will be higher than the average.
3. Friction is always a factor in any mechanical system, and it can affect the performance of your arm. Even with dual ball bearings and a timing belt/pulley system, there will still be some friction present. It's important to take this into account and maybe even add a safety margin to your calculations to ensure that the arm can still function smoothly even with some friction present.
Overall, your calculations seem to make sense and you have a good understanding of the mechanics involved. Just keep in mind the factors mentioned above and make sure to test and fine-tune your arm to ensure its smooth operation. Best of luck with your project!
Related to Calculation of torque for motion control camera arm
1. What is the purpose of calculating torque for a motion control camera arm?
The purpose of calculating torque for a motion control camera arm is to determine the amount of force or rotational motion that is required to move the camera arm in a desired direction or position. This is important for ensuring smooth and precise movements of the camera arm during filming.
2. How is torque calculated for a motion control camera arm?
Torque is calculated by multiplying the force applied to the camera arm by the distance from the pivot point of the arm to the point where the force is applied. This can be expressed as the formula: Torque = Force x Distance.
3. What factors affect the torque required for a motion control camera arm?
The torque required for a motion control camera arm is affected by several factors, including the weight of the camera and any additional equipment attached to the arm, the length and angle of the arm, and the speed and direction of movement.
4. How can the calculated torque be used to improve the performance of a motion control camera arm?
By accurately calculating the required torque, adjustments can be made to the camera arm's motor or gearing system to ensure that it can handle the necessary load and movement. This can help to improve the precision and smoothness of the camera arm's movements.
5. Are there any safety considerations when calculating torque for a motion control camera arm?
Yes, it is important to consider the maximum torque that the camera arm's motor and gearing system can safely handle. Exceeding this limit can cause damage to the equipment or result in unsafe movements. It is also important to regularly check and maintain the camera arm to ensure that it is functioning properly and safely.
  • Mechanical Engineering
9K
