Calculation when Mixing Two Compounds....
In summary: Combine terms of the same variable on one side. ..0.7x+y=0.8x+0.8y . .Then subtract 0.8x from both sides. ..-0.1x + y = 0.8y . .Subtract 0.8y from both sides. ..-0.1x = -0.2y . .Now multiply both sides by -10. ..x = 2y . .Multiply both sides by 0.5. ..y = 0.5x . .In summary, to achieve a concentration of 80% compound A and 20% compound B, you would need to mix 2 parts of the 70%
haubenkoch
Dear Comunity,
I am running into a (probably pretty simple) problem here, yet the most simple things are sometimes upon me...:(
I have a liquid solution which consists of 70% compound A and 30% compound B.
I also have a bottle with 100% compound A.
What I would like to do is to achieve a concentration of 80% compound A and 20% compound B. Can someone tell me how this is calculated?
I was thinking of something like c1*v1=c2*v2 but this doesn't get me anywhere...am I missing something?
Any help on this would be very much appreciated!
Mathematics news on Phys.org
I would set it up as follows:
Let $x$ be the amount of solution you currently have, the 7:3 mix. Then let $y$ be the amount of 100% compound A you wish to add. Thus we want:
\(\displaystyle 0.7x+y=0.8(x+y)\)
Do you see how both sides of the equation represent the amount of compound A present in the final solution? The left side represents the initial amount of compound A plus the amount added. The right side reflects the fact that we want 80% of the final amount to be compound A.
Now you may solve this for $y$ as a function of $x$. What do you find?
Hello, haubenkoch!
We can disregard references to compound B.
I have a liquid solution which is 70% alcohol.
I also have a bottle with 100% alcohol.
I would like a concentration of 80% alcohol.
This is an explanation of MarkFL's solution.Let [tex]x[/tex] = liters of 70% alcohol.
It contains [tex]0.7x[/tex] liters of alcohol.
We add [tex]y[/tex] liters of 100% alcohol.
It contains [tex]y[/tex] liters of alcohol.
The mixture contains [tex]0.7x + y[/tex] liters of alcohol. .[1]But we know that the mixture will be
. . [tex]x+y[/tex] liters which is 80% alcohol.
It contains [tex]0.8(x+y)[/tex] liters of alcohol. .[2]We just described the final amount of alcohol in two ways.
There is our equation! ..[tex]0.7x + y \:=\:0.8(x+y)[/tex]
FAQ: Calculation when Mixing Two Compounds....
How do you calculate the concentration of a mixture when mixing two compounds?
The concentration of a mixture is calculated by dividing the total amount of the compound by the total volume of the mixture. This can be expressed as a percentage or in molarity (moles per liter).
What is the equation for calculating the molarity of a solution?
The equation for calculating molarity is M = moles of solute / liters of solution. This equation can also be rearranged to solve for moles or liters, depending on the given information.
How do you determine the final volume of a mixture when combining two solutions?
The final volume of a mixture can be calculated by adding the volumes of the individual solutions. For example, if you mix 50 mL of Solution A with 75 mL of Solution B, the final volume of the mixture will be 125 mL.
What is the difference between molarity and molality?
Molarity is a measure of concentration in terms of moles per liter of solution, while molality is a measure of concentration in terms of moles per kilogram of solvent. Molarity is affected by changes in temperature, while molality is not.
How do you calculate the final concentration of a mixture when diluting a solution?
The final concentration of a mixture can be calculated using the formula M1V1 = M2V2, where M1 is the initial molarity, V1 is the initial volume, M2 is the final molarity, and V2 is the final volume. This formula is known as the dilution equation.
