Calculations for Poncelet (undershot) waterwheels
In summary, for information on the design of Poncelet water wheels, it is best to consult literature written by experienced engineers and online forums dedicated to water wheel design.
Jimbro
Could anyone provide me with, or point me in the direction of, any calculations for the design of Poncelet water wheels? Number of blades and blade shape/curvature in particular. I've had a trawl through the internet and looked through some papers but can't find much understandable information.
The best way to find information on the design of Poncelet water wheels is to consult literature written by experienced engineers in the field. Some useful resources include books like “The Design of Water Wheels” by L.H.P. Jones and “Hydraulic Turbines and Their Performance” by J.F.D.S. Andrade. These books provide detailed information on the design of Poncelet water wheels, including the number of blades and blade shape/curvature. Additionally, consulting online forums dedicated to water wheel design can be helpful in finding more specific information.
FAQ: Calculations for Poncelet (undershot) waterwheels
How do you calculate the efficiency of a Poncelet (undershot) waterwheel?
The efficiency of a Poncelet waterwheel can be calculated by dividing the theoretical power output by the actual power output. The theoretical power output can be calculated using the formula:
P = ρQgh, where P is power, ρ is the density of water, Q is the flow rate, g is the acceleration due to gravity, and h is the height of the wheel. The actual power output can be measured using a dynamometer or by using the weight of the water and the distance it falls.
What factors affect the efficiency of a Poncelet (undershot) waterwheel?
The efficiency of a Poncelet waterwheel can be affected by several factors, including the flow rate of the water, the height of the wheel, the weight of the water, and the design of the wheel. The efficiency can also be affected by external factors such as friction and turbulence in the water.
How do you determine the optimal height for a Poncelet (undershot) waterwheel?
The optimal height for a Poncelet waterwheel can be determined by considering the flow rate of the water and the desired power output. The height should be high enough to maximize the energy of the water, but not so high that the water loses momentum before reaching the wheel. Calculations and experiments can be used to determine the most efficient height for a specific waterwheel.
What is the difference between an overshot and an undershot waterwheel?
The main difference between an overshot and an undershot waterwheel is the direction of the water flow. In an overshot waterwheel, the water flows over the top of the wheel and causes it to rotate. In an undershot waterwheel, the water flows under the wheel, pushing against the paddles and causing it to rotate. Overshot waterwheels are typically more efficient than undershot waterwheels, as they can harness the energy of the water more effectively.
How do you calculate the torque of a Poncelet (undershot) waterwheel?
The torque of a Poncelet waterwheel can be calculated using the formula: T = F x r, where T is torque, F is the force acting on the wheel, and r is the radius of the wheel. The force can be calculated by multiplying the weight of the water by the distance it falls. The radius can be measured from the center of the wheel to the point where the force is applied. Torque is measured in newton-meters (N·m) or foot-pounds (ft·lbs).
