Calculations Made Easy for Beginners
In summary, the conversation discusses calculating surface area and energy using given measurements and units. It also mentions the importance of checking units and considering only one "side" of a person when calculating energy from the sun.
Acstars
Thank you <3
How about you start with question a)
It's an estimate, so go look in a mirror... as long as you don't come up with 5 cm² or 12 m² or something in m³ or kW/m you're fine.
For b), I think the question is fairly straightforward. But if you have no idea, you can look at the units. You are given something in J/(s m²), something in m² (from a) and something in s (a duration is given in the question). The units you need to have are J (Joules, you are asked for an energy). How can you combine these?
^___^
Acstars said:
For a if the average height was 170cm and the width is 30cm.
Surface area = height X width
SA = 170 X 30
SA = 5100cm
SA = 51m^2
It seems pretty off though?
5100cm² seems right, but there is an issue in your conversion to m².
^___^
FAQ: Calculations Made Easy for Beginners
How do I know which formulas to use for my calculations?
The formulas you use for your calculations will depend on the type of problem you are trying to solve. It is important to first identify the variables involved and then find the appropriate formula that relates those variables. It may also be helpful to refer to textbooks or online resources for guidance.
Can you explain the steps for solving these calculations?
Sure. The first step is to clearly define the problem and identify all the given information. Next, plug in the values into the appropriate formula and solve for the desired variable. It is important to show all your work and double check your calculations to avoid errors.
What should I do if I get stuck on a calculation?
If you get stuck on a calculation, take a break and come back to it later with a fresh mind. You can also try looking at the problem from a different perspective or asking a colleague for help. If all else fails, you can consult textbooks or online resources for additional explanations and examples.
How can I check if my calculations are correct?
There are a few ways to check if your calculations are correct. First, you can plug your final answer back into the original formula and see if it satisfies all the given information. You can also use estimation to see if your answer is within a reasonable range. Lastly, you can ask a colleague or your instructor to review your work and provide feedback.
Are there any tips for making calculations easier?
Yes, there are a few tips that can make calculations easier. First, make sure you are familiar with the basic arithmetic operations and order of operations. It may also be helpful to round off numbers to make them easier to work with. Additionally, breaking down a complex problem into smaller, manageable steps can make it less daunting. Lastly, practice makes perfect, so the more you practice, the easier calculations will become.
