Calculations of the needed horspower for a granulator
  • Thread starter Henk Trekker
  • Tags
    Calculations
In summary, this conversation is about a copper granulator. The expert comes out with a calculated need for 250 horsepower, and talks about the working principle of the machine.
Henk Trekker
I started calculating the needed horsepower for my project copper granulator. i come out on 250hp, its very high, i think i made a fault with the formule.
Cross section area ( i take blades of the rotor height * withd ) = height : 10 cm, Withd: 12 cm.
10 * 12 = 120 / 2 = 60^2 cm
Yield stress of copper: 4830 psi ( shearstress 80 % of yieldstress ) = 3864 psi
Riadial cutter distance: 35.35cm
Rpm: 2000founded Formules:
3864 x 0.60 = 2318.4 lbs of force
Torque = Force * Radial cutter distance
2318.4 * 0.3535 = 819.5544 Meter-kg of torque
Answer * rpm =
8,195,544 * 2000 = 1639,108.8 / 12 = 136,592.4 / 550 = 248.35 hp
I know i make a lot of faults, but i want to learn it.
I will very happy if anyone can help me out.
  • xxx.pdf
  • Assembly sxx.pdf
  • xxxsx.pdf
Hi @Henk Trekker -- What's a granulator? Is it like a defibrillator? Or an anihilattor? Or a bulldozer?
working principe is like a shredder, but i don't shred and work on higher rpm. A machine with knives on a rotor, it rotate at high rpm to granulate materials to fine materials ( granules ). this granulator wil make copper wires in 3-5 mm pieces.
You can look the ptf's to check the working of a granulator.
I try to calculate the horsepower that's need for the knives.
No, please don't ask us to have to do Google searches to help you. We really do want to help you, but asking us to do a lot of work to even start to help you is unreasonable.
Please post links to the reading you have been doing about these metal shreaders (is that right?), and ask us specific questions about the equations that you don't understand. Thanks.
Likes anorlunda
The blades in post #1 look more like chipper blades used for wood.
Because they are mounted square with the feed they will not "slice" cleanly, so will need more power to bash through the feed stock.
Yes they like the same but they are not made for copper. this technique will make smaller parts of the copper.
anorlunda said:
@Henk Trekker , this sounds like a continuation of your earlier thread.
https://www.physicsforums.com/threads/project-single-shaft-shredder.978021/#post-6239851
Your shredder description also sounds much like the shredders in the video below. However, where those operate at 2-5 RPM, you say 2000 RPM. Why do you think you need such a high speed?
Thats a shredder, shredder are shredding the material at low rpm high torque. granulator work in higher rpm to make granules of the material, I'm also happy if its work on 500rpm but i need first to calculate the torque and horsepower it needs to work.
Thank you sir for helping, my asnwer is in metric but i cannt find the answer of my fault in the formule. how did you calculate 61.67 ft-pounds.
I did not. See post #5 by @Tom.G
It is a good idea to label all numbers with their units for clarity.
If 2318.4 is pounds of force, and 0.3535 meters is radial cutter distance, then how can 819.5544 be in meter-kg?
I've the same question about requiring 2000 RPM as @anorlunda. My experience is with plastics granulators, and I'm having a hard time envisioning it's copper-cutting cousin surviving operation at this speed.
How is size grading accomplished? With plastics, a screen with a matrix of appropriately sized holes (typically, 1/4" to 1/2", depending on throughput and granule size requirements) is positioned under the cutting chamber, and particles fall through only after they've become small enough. Making smaller granules requires more residence time in the cutting chamber (for example, instead of being cut to size in 1 or 2 blade passes with a 1/2" mesh, cutting granules to 1/4" will require many more cuts), and reduces throughput.
The reason for bring this up is, as input lb/hr approaches what can be taken away, granule volume in the cutting chamber increases, and more power will be required to "churn" them. If applicable in this case, this extra power demand must be accounted for.
Likes Henk Trekker
@Asymptotic Thank you sir for the information, I have a design a screen with D 0.6 mm holes , 0.5 mm distance from the blades to the screen. What is a save rpm lvl?
Can't say how fast will be safe. A lot of this is determined by granulator design - what the bearings can handle, how much impact force the blade hold-down bolts can successfully clamp against, maximum ratings of various power train components (such as V-belt sheaves), and so on.
600 RPM is fairly representative of plastics granulator speeds.
Dimensions of 0.6 mm diameter for screen hole size, and 0.5 mm screen-to-blade distances don't seem right.
A grain of table salt is roughly 0.3 mm.
Related to Calculations of the needed horspower for a granulator
1. How do you calculate the needed horsepower for a granulator?
To calculate the needed horsepower for a granulator, you will need to determine the material's bulk density, desired throughput rate, and the specific energy required for the material. Then, you can use the formula: horsepower = (bulk density x throughput rate x specific energy) / 33000.
2. What is bulk density and why is it important in horsepower calculations for a granulator?
Bulk density refers to the weight of a material per unit volume. It is important in horsepower calculations because it determines the amount of material that can be processed in a given amount of time. Higher bulk density materials will require more horsepower to process at the desired throughput rate.
3. How does the desired throughput rate affect the needed horsepower for a granulator?
The desired throughput rate is the amount of material that needs to be processed within a specific time frame. It directly impacts the needed horsepower for a granulator, as a higher throughput rate will require more power to process the material effectively.
4. What is specific energy and why is it important in calculating the needed horsepower for a granulator?
Specific energy is the amount of energy required to process a unit of material. It is important in horsepower calculations because it determines the power needed to process a specific material. Different materials will have different specific energy requirements, which will impact the needed horsepower for a granulator.
5. Are there any other factors that can affect the needed horsepower for a granulator?
Yes, there are other factors that can affect the needed horsepower for a granulator, such as the size and type of granulator, the type of material being processed, and the desired final product size. It is important to consider all of these factors when calculating the needed horsepower for a granulator.
33K
  • Mechanics
  • General Engineering
34K
