Calculus 2 for Engineers: Riemann sums
In summary, the conversation is about finding a Riemann sum for the integral of x^3 from 0 to 1 and proving that it converges to 1/4 using the given identity. The speaker has successfully completed part a by obtaining the sum ∑i^3/N^4 from i=0 to N-1, and is struggling with part b but is given a hint to use the right end point of each interval in the sum provided by the other speaker. After some further discussion, the speaker is able to successfully solve part b and thanks the other speaker for their help.
Parker Hays
a. Write down a Riemann sum for the integral ∫x3dx from 0 to 1.
b. Given the following identity 13+23+33...+N3=(N(N+1)/2)2, show that the Riemann sums for ∫x3dx from 0 to 1 converge to 1/4.
I believe I have gotten part a. I got ∑i^3/N^4 from i=0 to N-1. Part b I have attempted to solve from multiple angles for the past hour but none of the ways I've tried have yielded any positive results.
Try using the right end point of each interval so you have$$
\sum_{i=1}^n \frac{i^3}{n^3}\cdot \frac 1 n$$
Yes, I got part a correct. However, part b still does not make sense to me. I have tried solving for N^4 and various other strategies but I don't see how I can plug it in or do anything to get that it converges to 1/4.
Show me what you have done with the sum I gave you. Have you used the given hint?
I had already completed part a correctly, and you didn't give me a hint for part b.
He did. Use the sum in post #2 with the sum you have for b) and calculate the limit.
I figured it out. Thanks for the help, sorry I didn't realize you were giving me another idea I just thought you were restating the answer I already had for part a @LCKurtz.
Related to Calculus 2 for Engineers: Riemann sums
1. What is the purpose of Riemann sums in Calculus 2 for Engineers?
Riemann sums are used to approximate the area under a curve by dividing the region into smaller rectangles and calculating the sum of their areas. In Calculus 2 for Engineers, Riemann sums are used to solve problems involving continuous functions and to find the volume of solids of revolution.
2. How are Riemann sums calculated?
Riemann sums are calculated by dividing the interval of the function into smaller subintervals and evaluating the function at specific points within each subinterval. The sum of these function values multiplied by the width of each subinterval gives an approximation of the area under the curve.
3. What is the difference between a left, right, and midpoint Riemann sum?
A left Riemann sum uses the left endpoint of each subinterval to evaluate the function, a right Riemann sum uses the right endpoint, and a midpoint Riemann sum uses the midpoint of each subinterval. The accuracy of the approximation depends on the choice of Riemann sum, with the midpoint Riemann sum generally being the most accurate.
4. How do Riemann sums relate to the definite integral?
Riemann sums are used to approximate the value of a definite integral. As the number of subintervals increases, the Riemann sum becomes a more accurate approximation of the definite integral. In the limit, as the number of subintervals approaches infinity, the Riemann sum becomes equal to the definite integral.
5. Can Riemann sums be used to approximate the area under a curve for any function?
Riemann sums can be used to approximate the area under a curve for any continuous function. However, the accuracy of the approximation may vary depending on the characteristics of the function, such as its shape and behavior. In some cases, other methods such as the Trapezoidal Rule or Simpson's Rule may provide a more accurate approximation.
