Calculus BC Trigonometric Substitition
In summary, the conversation discussed how to simplify the integral \int \frac {\sqrt {1+x^2}}{x} \, dx and how to integrate it using u-substitution. The final answer was found to be \ln |\frac{\sqrt{1+x^2}-1}{x}|+\sqrt{1+x^2}+C by simplifying using previous substitutions and logarithm rules.
hwmaltby
[tex]\int \frac {\sqrt {1+x^2}}{x} \, dx[/tex]
[tex]\sin^2{\theta}+\cos^2{\theta}=1[/tex]
[tex]x=\tan{\theta}[/tex]
I simplified it down to:
[tex]\int \frac {1}{\sin{\theta} \cdot \cos^2{\theta}} \, d\theta[/tex]
Which I do not know how to integrate.
Any help would be wonderful!
Never mind... I rewrote it as:
[tex]\int \csc{\theta}\cdot\sec^2{\theta} \, d\theta[/tex]
And used u-substition:
[tex]u=\sec{\theta}[/tex]
[tex]\int \frac{\csc{\theta} \cdot \sec^2{\theta}}{\tan{\theta} \cdot \sec{\theta}} \, du [/tex]
[tex]\int \csc^2{\theta} \, du[/tex]
[tex]\int \frac{u^2}{u^2-1} \, du[/tex]
[tex]\frac{1}{2} \cdot \ln |\frac{u-1}{u+1}| +u+C [/tex]
I then simplified using my previous substitutions and logarithm rules to get my final answer:
[tex] \ln |\frac{\sqrt{1+x^2}-1}{x}|+\sqrt{1+x^2}+C [/tex]
And you can check by differentiating your answer. If you end up with sqrt(1 + x^2)/x, you're golden.
FAQ: Calculus BC Trigonometric Substitition
What is trigonometric substitution in Calculus BC?
Trigonometric substitution is a technique used in Calculus BC to simplify integrals involving complex expressions. It involves replacing the variable in the integral with a trigonometric function and using trigonometric identities to simplify the integral.
When should I use trigonometric substitution in Calculus BC?
Trigonometric substitution should be used when the integral contains a radical expression or an expression that involves the square root of a sum of squares. It is also useful when integrating expressions involving trigonometric functions such as sine, cosine, and tangent.
How do I choose which trigonometric function to substitute in Calculus BC?
The choice of which trigonometric function to substitute depends on the expression within the integral. The goal is to choose a trigonometric function that will eliminate the radical or simplify the expression. This is often done by looking for a trigonometric identity that can be used to rewrite the expression in a simpler form.
What are the common trigonometric identities used in Calculus BC trigonometric substitution?
Some common trigonometric identities used in trigonometric substitution include the Pythagorean identities (sin2(x) + cos2(x) = 1), double angle formulas (sin(2x) = 2sin(x)cos(x)), and the power-reducing identities (sin2(x) = (1-cos(2x))/2). It is important to have a good understanding of these identities when using trigonometric substitution.
What are the benefits of using trigonometric substitution in Calculus BC?
Trigonometric substitution can simplify complex integrals and make them easier to solve. It also allows for the use of familiar trigonometric identities and techniques, making it a useful tool for solving more advanced integration problems in Calculus BC.
