Calculus by Spivak Trichotomy Law
In summary, the Trichotomy law states that for every number, one of the following three properties must be met: (i) it is 0 (zero), (ii) it is in the collection P, or (iii) it is in the collection -P.
Bashyboy
1,421
In the third edition, on page 9, I am reading about the Trichotomy law.
It says, for every number a, one and only one of the following properties holds
(i) a = 0
(ii) a is in the collection P,
(iii) -a is in the collection
Before stating this, though, the author said that P is the collection of all positive numbers (set of positive numbers). If P is the set of positive numbers, how can negative a be in P?
What if -a is positive ? As I can see, there's no restriction on a.
Oh, so, for instance, if a = - 2, then -(-2) would be part of the set P.
what if a was a complex number or a quaternion?
This still seems odd to me. One of the following three properties will always be met, meaning that all numbers are in the set of positive numbers, P. Why is this description of the law of trichotomy so different from others I have seen?
Bashy, it says that for each number, only one of those is true. It does not say that for each number, if one is true then the number is in P.
For the number 2:
Either 2=0 (nope), 2 is in P (yup) or -2 is in P (nope).
For -2:
-2=0(nope), -2 is in P (nope) or -(-2) is in P (yup).
So we see that even though the property is satisfied for both -2 and 2, in both cases it's only saying that 2 is positive, and not -2.
Ah, I see. Thank you very much. One more question, would you agree that the law of trichotomy is not generally stated in this way?
No, I have seen it stated that way (word for word basically) in several other places, though I don't know if it was explicitly called the law of trichotomy.
you are making the mistake of reading the sign - as "negative" rather than minus. a number is negative if it is less than zero. but minus a number is negative or positive if and only if the original number is respectively positive or negative. Thus: do not read "-" as "negative", but as 'minus". Unfortunately I will never live long enough to make this point.
FAQ: Calculus by Spivak Trichotomy Law
What is the Trichotomy Law in Calculus by Spivak?
The Trichotomy Law in Calculus by Spivak refers to the fundamental theorem that states every real number can be classified as either positive, negative, or zero. This law is essential in understanding the behavior of functions and solving calculus problems.
How is the Trichotomy Law used in Calculus by Spivak?
The Trichotomy Law is used in Calculus by Spivak to categorize real numbers and define their properties. It is also used to compare and order numbers, which is crucial in solving equations and inequalities in calculus.
What are the implications of the Trichotomy Law in Calculus by Spivak?
The Trichotomy Law has several implications in calculus. It allows for the precise description of real numbers and their relationships, making it easier to solve problems involving functions and derivatives. It also helps establish the foundations of calculus and its applications in various fields.
Can the Trichotomy Law be applied to complex numbers in Calculus by Spivak?
No, the Trichotomy Law only applies to real numbers in Calculus by Spivak. Complex numbers have different properties and cannot be classified as positive, negative, or zero. However, the law's principles can still be used in complex analysis to study functions of complex variables.
How does the Trichotomy Law relate to other laws in Calculus by Spivak?
The Trichotomy Law is closely related to other fundamental laws in calculus, such as the Law of Trichotomy, the Law of Additive Inversion, and the Law of Multiplicative Inversion. These laws work together to define the properties of real numbers and their operations, which are essential in solving calculus problems.
