Calculus I: Monotinic Functions and First Derivative Test
In summary, the derivative function f'(x) = (x-1)^{2}(x+2)^{2} has critical points at x=1 and x=-2, and is increasing on all intervals except (-inf, -2), where it is decreasing. The graph of the derivative is a product of squares, which is always nonnegative, resulting in the graph of the original function, f(x), being increasing on all intervals except the critical points. The critical points of the derivative do not necessarily correspond to the critical points of the original function, and it is important to keep the terminology clear when discussing these concepts.
Cod
325
Using the derivative f'(x) = (x-1)[tex]^{2}[/tex](x+2)[tex]^{2}[/tex] answer the following:
a) What are the critical points of f?
b) On what intervals is f increasing or decreasing?
c) At what points, if any, does f assume local maximum and minimum values?
n/a
From strictly observing the derivative and using the quadratic equation to check, the critical points are x=1 and x=(-2). Once I pick a number within each of the intervals (-inf, -2), (-2, 1), and (1, inf) and implement it into the equation, I consistently get positives. By definition of Corollary 3: First Derivative Test for Monotonic Functions, the equation would be increasing on every interval; therefore, making a line. The problem is, when I graph the answer to check my solution, I notice a critical point at x=(-.05). Where did this CP come from and how do I figure it out algebraically?
Any guidance would be greatly appreciated.
n/a
You should be able to tell by nothing more than inspection that the critical numbers are 1 and -2.
You're just substituting values into the derivative function, not implementing anything.
True, the derivative is positive everywhere except at x = 1 and x = -2, which means that the slope of the function f is >= 0, but that doesn't make the graph of f a line. For example, if f(x) = ln(x), f'(x) = 1/x > 0 for all x > 0, but the graph of the natural log function is not a line.
The only critical numbers are 1 and -2. Your value of -.05 might have come from your mistaken assumption that the graph of the underlying function was a straight line. It isn't.
What function did you plot?
BTW, a very quick way to see that the first derivative is everywhere nonnegative is that it's a product of squares.
Tinyboss, I plotted the derivative that was provided: [(x-1)^2][(x+2)^2].
Mark44, thanks for the explanations; however, I'm still failing to understand how the derivative is decreasing over the interval (-.5, 1). I realize that if I found the original function it may be easier, but according to the textbook and my instructor, we should be able to get all the answers strictly from the first derivative. Sorry if I'm frustrating you, I just can't get my nugget wrapped around this question.
Thanks again for the help y'all.
Why shouldn't the derivative decrease on that interval? As long as the derivative is positive, the original function will be increasing.
I thought for the function to be decreasing along an interval, the derivative had to be less than 0 when you substitute any value from within that interval. Isn't that correct? For example, if I evaluate at f(0), I still get a positive even though the function is decreasing on the interval (-.5, 1). Shouldn't I get a negative since the function is decreasing along that interval?
With this problem, you really have keep your terminology clear, or you will confuse yourself and anyone trying to understand you. You are given a function f' that is already the derivative of some unknown function f. If you start talking about the derivative, are you talking about f' or are you talking about its derivative, f''?
You said in another post that you graphed y = f'(x) = (x + 2)^2(x - 1)^2. The zeroes of this graph are at -2 and 1. The y-values on this graph are zero at x = - 2 and x = 1, and are positive everywhere else. This graph (y = f'(x)) is decreasing on (-inf, -2), increasing on (-2, ~-.5), decreasing on (~-.5, 1), and increasing on (1, inf). The increasing and decreasing here tell you about the sign of the derivative of the derivative, i.e., f''.
The sign of the derivative tells you where the underlying (and unknown) function f is increasing and decreasing. Since the graph of y = f'(x) is greater than or equal to zero for all x, the graph of y = f(x) is increasing on (-inf, -2), (-2, 1), and (1, inf).
That makes sense Mar44. Sorry I was using confusing verbage, I didn't realize I was. Thanks for the explanation and "putting up with me".
Related to Calculus I: Monotinic Functions and First Derivative Test
1. What is a monotonic function?
A monotonic function is a function that either always increases or always decreases as its input variable increases. In other words, the function either has a positive slope or a negative slope, but not both.
2. What is the first derivative test?
The first derivative test is a method used to determine the local extrema of a function. It involves finding the critical points of the function (where the first derivative is equal to zero) and then analyzing the sign of the derivative on either side of these points to determine if they are local maxima or minima.
3. How do you determine if a function is increasing or decreasing?
To determine if a function is increasing or decreasing, you can take the first derivative of the function and analyze its sign. If the derivative is positive, the function is increasing. If the derivative is negative, the function is decreasing.
4. Can a function be both increasing and decreasing?
No, a function cannot be both increasing and decreasing. A function can only have one type of monotonicity (either increasing or decreasing) over a given interval.
5. What are critical points in calculus?
Critical points are points on a function where the first derivative is equal to zero or does not exist. These points are important in calculus because they can indicate where the function has a local extremum (maximum or minimum) or a point of inflection.
