Calculus II - closed function question
In summary: F and f and x in relation to t?sorry about the wrong copying: g(t)=f(t,1-t^6)In summary, you are trying to find the inverse function of g(1), which is 2ln(g(1)). Differentiating with respect to t, you get: \frac{2}{tg}(1+ tg')+ cos(t(1- t^6)g)((1- t^6)g- 6t^6g+ t(1-t^6)g')
axcelenator
33
there is a function: F ( x, y, z) = 2ln (xz) + sin ( xyz) − y^2 = 0.
the func is defined by the closed function z=f(x,y) and provides : f(1,0)=1
we define: g(t)=f(t,1-t^6) . where t is very close to 1.
I have to find g'(1)
I tried to to do like that: find F'x and F'z and did z'x =-(F'x/ F'z) and got -1. but from here I don't know what to do.
The answer is g'(1)=2.
Thanks for your help!
sorry, can't really follow this - can you explain the question in a little more detail and more clearly? for example what is g in relation to F and f and x in relation to t?
Are you saying there exist f(x,y) such that z= f(x,y), in the neighborhood of (1, 0, 1), is the same as [itex]2ln(xz)+ sin(xyz)- y^2= 0[/itex]?
If so, then F(x, y, g)= 2ln(xg)+ sin(xyg)- y^2= 0. And with x= t, y= 1- t^6, that is 2ln(tg)+ sin(t(1- t^6)g)- (1- t^6)^2.
[tex]\frac{2}{tg}(1+ tg')+ cos(t(1- t^6)g)((1- t^6)g- 6t^6g+ t(1-t^6)g')- 12(1- t^6)t^5= 0[/tex]
Set t= 1, so that x= 1, y= 0, and F(1, 0, g(1))= 2ln(g(1))= 0. What is g(1)? Put x= 1, y= 0, and that value of g(1) into the equation and solve for g'(1).
FAQ: Calculus II - closed function question
What is a closed function in Calculus II?
A closed function in Calculus II refers to a function that is defined and continuous over a closed interval. This means that the function has no discontinuities or gaps within the given interval.
How is a closed function different from an open function?
A closed function is different from an open function in that it includes the endpoints of a given interval, while an open function does not. This means that a closed function is defined and continuous at every point within the interval, including the endpoints.
What are the key properties of a closed function?
The key properties of a closed function include continuity, boundedness, and having a maximum and minimum value within the given interval. These properties help to ensure that the function is well-defined and behaves predictably over the entire interval.
How are closed functions used in Calculus II?
Closed functions are used in Calculus II to study the behavior of functions over a specific interval. They are also used to determine the area under a curve, as they have a defined and continuous value at every point within the interval.
Can a closed function have an infinite number of solutions?
No, a closed function cannot have an infinite number of solutions. This is because a closed function is defined and continuous over a specific interval, and therefore has a finite number of solutions within that interval.
