Calculus II Help : Taylor/Maclaurin Series
The Maclaurin series for arctan(x) is x- x^3/3+ x^5/5- x^7/7+ ... and the Maclaurin series for arctan(x^3/3)= (x^3/3)- (x^3/3)^3/3+ (x^3/3)^5/5- ...= x^3/3- x^9/27+ x^15/243- ...
vdeity
Hey... This really sucks. I am in Calculus 2 and I have had 3 in-class exams, all 3 were A's. This last exam is take-home and it is entirely Maclaurin and Taylor series.. The only thing in the class to go over my head.
Please help me out with these problems!
Use the function : f(x) = 1 / x^2 to answer the following questions.
#1
a. Find a formula for the sequence of values given by f^n (2). Do this by computing enough derivatives of f(x) evaluated at 2 until you see a pattern.
I got
Σ ( (-1)^(n+1) * (n+1)! ) / ( -2 * 2^(n+1) )
n=0
b. Find formula for the sequence of values given by f^n (2) / n!
I got like... ( (-1)^n (n+1)! ) / (4 * 2^n )
c. What is the Taylor Series centered at a = 2 for the function f(x) = 1/x^2 ?
Σ ( f^n*(2)*(x-2)^n ) / n!
n=0
d. What is interval of convergence for this Taylor series?
No bueno.
e. What is T4 (x) ?
f. What are T4(3) and R4 (3) ?
#2
a. Find Maclaurin Series for the function:
F(x) =
x⌠ t^2 * e^ (-t^2) dt
0⌡
*Remember : e^x =
Σ [ f^n * (a) * (x-a)^n ] / n!
n=0
I got... (something that didn't work)
[ (-1)^n * t^2 (t^(2n) ] / n!
b. Estimate value of
1⌠ x^2 * e^(-x^2) dx
0⌡
by using M9(x), the Maclaurin polynomial of degree 9.
#3
a. Find the Maclaurin series for the function f(x) = arctan ( x^3 / 3 )
b. What is the interval of convergence?
c. Find the value of the first 10 coefficient terms: c0, c1, c2, c3, c4 ... c10 for this Maclaurin series.
d. What is the value of f^21 (0), the 21st derivative evaluated at zero?
#1
I got
n=0
You mean the nth derivative, not f to the nth power here, don't you? f(x)= x-2 so f(2)= 1/4; f'(x)= -2x-3 so f'(2)= -1/4; f"(x)= 6x-4 so f"(2)= 3/8; f"'(x)= -12x-5 so f"'(2)= 3/16, etc. I don't see where you got that sum.
The only difference between (a) and (b) is that you have divided by n!. What happened to the sum? Why do you still have (n+1)!? (n+1)!/(n+1)= n+1.
n=0
That's the formula, yes, but obviously you are expected to use your answers from (a) and (b)!
No bueno.
I can think of two ways to find the radius of convergence.
a) Use the ratio test for convergence
b) What is the distance from x= 2 to the point where f(x) "blows up"?
e. What is T4 (x) ?
If you were able to do (c) why not just set x= 2?
#2
F(x) =
0⌡
*Remember : e^x =
n=0
First it should be a function of x, not t! Did you forget to integrate?
0⌡
#3
At try 3!
FAQ: Calculus II Help : Taylor/Maclaurin Series
1. What are Taylor and Maclaurin series in Calculus II?
Taylor and Maclaurin series are mathematical tools used in Calculus II to represent a function as an infinite sum of simpler functions. They are used to approximate the behavior of a function near a specific point by using its derivatives.
2. How are Taylor and Maclaurin series different?
The main difference between Taylor and Maclaurin series is that Maclaurin series are centered at x=0, while Taylor series can be centered at any point. This means that the coefficients in a Maclaurin series are all derived from the derivatives at x=0, while the coefficients in a Taylor series can be derived from the derivatives at any point.
3. How do I find the coefficients for a Taylor/Maclaurin series?
To find the coefficients for a Taylor/Maclaurin series, you need to take the derivatives of the function at the desired center point and evaluate them at that point. Then, plug these values into the formula for the Taylor/Maclaurin series.
4. What is the purpose of using Taylor/Maclaurin series?
The purpose of using Taylor/Maclaurin series is to approximate a function and its behavior near a specific point. They are useful in simplifying complicated functions and making them easier to work with, especially in problems involving integration and differentiation.
5. Can Taylor/Maclaurin series be used for any type of function?
Yes, Taylor/Maclaurin series can be used for any continuous and differentiable function. However, the accuracy of the series may vary depending on the complexity of the function and the number of terms included in the series.
