MHB Calculus II: Work Required to Pump Water from Hemispherical Tank
The problem involves calculating the work required to pump water from a hemispherical tank with a radius of 10 meters, initially filled to a depth of 6 meters, down to a depth of 2 meters. The setup involves slicing the tank into horizontal circular sheets to determine the volume and weight of each sheet, which is influenced by its distance from the top of the tank. The work done to lift each sheet is expressed in terms of the weight density of the fluid and the distance it must be lifted. By integrating this expression between the initial and final depths, the total work required is calculated, resulting in a final value of approximately 89689600π Joules. This method provides a systematic approach to solving similar problems in calculus involving fluid mechanics.
MarkFL
MHB
Here is the question:
Hemispherical dome - Calculus II question?
I have a problem that I can't figure out how to set up. I'm really bad at word problems.
1) A hemispherical dome of radius 10 meters is filled with water to a depth of 6 meters. How much work is needed to pump out water through the top of the dome until the depth is 2 meters? (Note: the dome's flat side rests on flat ground.)
An explanation would be really helpful. The set up is the part that I struggle with the most, so if anyone could provide it, that would be helpful.
Thanks!
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Hazue,
I prefer to work problems like this in general terms, and then plug our given data into the resulting formula.
First, let's let:
$R$ = the radius of the hemispherical tank.
$\rho$ = the weight density of the fluid.
$g$ = the acceleration due to gravity.
Now, let's imagine slicing the contents of the tank horizontally into circular sheets. The radius of each sheet will be a function of its distance from the base of the tank. So, let's orient a vertical $y$-axis passing through the axis of symmetry of the tank, with its origin at the base of the tank.
The circular portion of the cross-section of the tank containing our $y$-axis will lie on the circle:
$$x^2+y^2=R^2$$
And so, for any circular sheet, its radius will be the $x$-coordinate of a horizontal line passing through the circle, and so we may state:
$$r^2=R^2-y^2$$
Hence, the volume of an arbitrary sheet can be given by:
$$dV=\pi\left(R^2-y^2 \right)\,dy$$
Next, we want to determine the weight $w$ of this sheet. Using the definition of weight density, we may state:
$$\rho=\frac{w}{dV}\,\therefore\,w=\rho\,dV$$
Next, we observe that the distance $d$ this sheet must be lifted is:
$$d=R-y$$
Thus, using the fact that work is the product of the applied force and the distance through which this force is applied, we find the work done to lift the arbitrary sheet is:
$$dW=wd=\pi\rho(R-y)\left(R^2-y^2 \right)\,dy$$
Distributing, we find:
$$dW=\pi\rho\left(R^3-R^2y-Ry^2+y^3 \right)\,dy$$
Now, if $y_i$ is the initial depth of fluid in the tank, and $y_f$ is the final depth, where $0\le y_f<y_i\le R$, then the total amount of work required to pump out the required amount of fluid is given by:
$$W=\pi\rho\int_{y_f}^{y_i} R^3-R^2y-Ry^2+y^3\,dy$$
Applying the FTOC, there results:
$$W=\pi\rho\left[R^3y-\frac{1}{2}R^2y^2-\frac{1}{3}Ry^3+\frac{1}{4}y^4 \right]_{y_f}^{y_i}=\frac{\pi\rho}{12}\left[12R^3y-6R^2y^2-4Ry^3+3y^4 \right]_{y_f}^{y_i}$$
And so we find:
$$W=\frac{\pi\rho}{12}\left(y_i-y_f \right)\left(12R^3-6R^2\left(y_i-y_f \right)-4R\left(y_i-y_f \right)^2+3\left(y_i-y_f \right)^3 \right)$$
Now, we are given the following data for this particular problem:
$$\rho=\frac{1000\text{ kg}}{\text{m}^3}\cdot9.8\frac{\text{m}}{\text{s}^2}=9800\frac{\text{N}}{\text{m}^3},\,R=10\text{ m},\,y_i=6\text{ m},\,y_f=2\text{ m}$$
Plugging these values into our formula, we obtain:
$$W=\frac{2450\pi}{3}(6-2)\left(12(10)^3-6(10)^2(6-2)-4(10)(6-2)^2+3(6-2)^3 \right)\text{ J}=\frac{89689600\pi}{3}\text{ J}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
