Calculus of parametric equations (finding surface area)
In summary, the surface area of the curve x=e^tsint and y=e^tcost when revolved around the x-axis is 2π times the integral of f(x) times the square root of 1 plus the derivative of f(x) squared, with the limits of integration being from 0 to π/2. When revolved around the y-axis, the surface area is 2π times the integral of x times the square root of 1 plus the derivative of f(x) squared, with the same limits of integration.
jrg_pz
I was wondering what the surface area would be when the curve:
x=e^tsint,
and y=e^tcost where (t) is greater than or equal to (0) and (t) is less
or equal to pi divided by (2).
when it is revolved about
a) the x-axis
b) the y-axis (approximation with calc. (how?))
x=e^tsint,
a) the x-axis
Around the x-axis you have:
[tex]\text{SA}_x=2\pi\int_{a}^{b}f(x)\left(\sqrt{1+f'(x)^2}\right)dx[/tex]
...the y-axis you have:
[tex]\text{SA}_y=2\pi\int_{a}^{b}x\left(\sqrt{1+f'(x)^2}\right)dx[/tex]
And I assume you can figure out what f(x) and dx are in terms of your parametric equations...
I am happy to provide a response to your inquiry about the surface area of a curve defined by parametric equations. In order to find the surface area when the curve is revolved about the x-axis or y-axis, we can use the formula for surface area of revolution, which is given by:
S = 2π∫a^b y√(1 + (dy/dx)^2) dx
Where a and b are the limits of t, and dy/dx is the derivative of y with respect to x. Let's break down the steps for finding the surface area in each case:
a) When the curve is revolved about the x-axis, we can use the formula above with a=0 and b=π/2, since these are the limits given in the problem. We can also rewrite the parametric equations in terms of x and y as:
x = e^tsin(t) → y = e^tcos(t)
Taking the derivative of y with respect to x, we get:
dy/dx = (dy/dt)/(dx/dt) = cos(t)/sin(t)
Substituting this into the formula for surface area, we get:
S = 2π∫0^(π/2) e^tcos(t)√(1 + (cos(t)/sin(t))^2) dt
Using a calculator or integration techniques, we can evaluate this integral to find the surface area.
b) When the curve is revolved about the y-axis, we can use the same formula as above, but with a=0 and b=e^π/2. This is because when we revolve the curve around the y-axis, the limits of integration will be from y=0 to the maximum value of y, which is given by e^π/2. We can also rewrite the parametric equations in terms of x and y as:
S = 2π∫0^(e^(π/2)) e^tcos(t)√(1 + (cos(t)/sin(t))^2) dt
Again, using a calculator
Related to Calculus of parametric equations (finding surface area)
What is the calculus of parametric equations?
The calculus of parametric equations involves using calculus techniques, such as integration and differentiation, to analyze and solve problems involving parametric equations. These are equations that describe a relationship between two or more variables, usually represented as a set of equations or as a vector function.
How do you find the surface area of a parametric curve?
To find the surface area of a parametric curve, you can use the formula:
A = ∫√(x'(t)² + y'(t)²) dt. This involves taking the integral of the square root of the sum of the squares of the derivatives of the parametric equations with respect to the parameter t. This represents the arc length of the curve, which can then be used to calculate the surface area.
What is the difference between a parametric curve and a regular curve?
A regular curve is typically described with a single equation, such as y = f(x), while a parametric curve is described with multiple equations or as a vector function, such as x = f(t) and y = g(t). This allows for more complex and dynamic curves to be represented, making them useful in applications such as physics and engineering.
Can parametric equations be used to find the surface area of 3D objects?
Yes, parametric equations can be used to find the surface area of 3D objects. This involves using multiple parametric equations to represent the different surfaces of the object, and then using the same formula for finding the surface area of a parametric curve. This can be a powerful method for finding surface area in complex 3D shapes.
What are some real-world applications of the calculus of parametric equations?
The calculus of parametric equations has numerous real-world applications, including in physics, engineering, and computer graphics. Some examples include calculating the trajectory of a projectile, modeling the motion of a pendulum, and creating 3D animations and simulations.
