Calculus of variations question
In summary, the functional in question is:$$J\left[\phi,y,z\right]=\int_0^b\left( \int^b_0\left( \dot{\phi}(t)\frac{(y(s)-y(t))\dot{y}(s)+(z(s)-z(t))\dot{z}(s)}{(y(s)-y(t))^2+(z(s)-z(t))^2} \right)dt + \Lambda\left(a\phi(s)\dot{y}(s)-c\right) \right)ds$$In summary
phi1123
Okay, so I've run into a rather weird functional that I am trying to optimize using calculus of variations. It is a functional of three functions of a single variable, with a constraint, but I can't figure out how to set up the Euler-Lagrange equation. The functional in question is (sorry it's kind of messy):
I'm wondering as to what exactly the best way to deal with the inner integral is. I've considered pulling out the inner integral, and rewriting the whole thing as:
$$J\left[\phi,y,z\right]=\int_0^b \int^b_0\left( \dot{\phi}(t)\frac{(y(s)-y(t))\dot{y}(s)+(z(s)-z(t))\dot{z}(s)}{(y(s)-y(t))^2+(z(s)-z(t))^2} + \Lambda\left(\frac{a}{b}\phi(s)\dot{y}(s)-\frac{c}{b}\right) \right)dsdt$$
and then taking the integrand as my Lagrangian in the Euler-Lagrange equation, but then I seem to run into trouble with having to different independent variables as the argument to the functions ##\phi, y,z##. Anyone have any experience with similar problems? Thanks for your help!
You cannot use the Euler-Lagrange equation because it assumes that the variable is only integrated over a single time. Instead, you may want to review how the EL equation is derived and see if you can do something similar.
So I've been thinking about this problem some more (sorry I didn't reply earlier). Following your suggestion, let's assume only ##\phi## is varied for simplicity. In that case we want to minimize a functional of the form
$$J[\phi]=\int^b_0\int^b_0L(\phi(s),\phi(t),\dot{\phi}(s),\dot{\phi}(t))dsdt$$
Then setting ##\frac{d}{d\epsilon}J[\phi+\epsilon\eta]=0## at ##\epsilon=0##, we get
$$\frac{d}{d\epsilon}J[\phi+\epsilon\eta]=0=\int^b_0\int^b_0 \left( \frac{\partial L}{\partial\phi(s)}\eta(s) + \frac{\partial L}{\partial\phi(t)}\eta(t) +\frac{\partial L}{\partial\dot{\phi}(s)}\dot{\eta}(s) + \frac{\partial L}{\partial\dot{\phi}(t)}\dot{\eta}(t) \right)dsdt$$
Separating out the s & t terms, and doing integration by parts
$$0=\int^b_0\int^b_0 \left( \frac{\partial L}{\partial\phi(s)} - \frac{\partial}{\partial s}\left( \frac{\partial L}{\partial\dot{\phi}(s)} \right) \right)\eta(s) dsdt + \int^b_0\int^b_0 \left( \frac{\partial L}{\partial\phi(t)} - \frac{\partial}{\partial t}\left( \frac{\partial L}{\partial\dot{\phi}(t)} \right) \right)\eta(t) dsdt$$
Therefore the differential equations describing the function that maximizes J will be the two equations:
$$\frac{\partial L}{\partial\phi(s)} - \frac{\partial}{\partial s}\left( \frac{\partial L}{\partial\dot{\phi}(s)} \right)=0$$
$$\frac{\partial L}{\partial\phi(t)} - \frac{\partial}{\partial t}\left( \frac{\partial L}{\partial\dot{\phi}(t)} \right)=0$$
I can't think of any way to simplify this further, and I could very well have made some silly mistake, so if you have any thoughts, they'd be appreciated!
One thing that's bugging me about the above is that it doesn't seem to be "symmetrical" with respect to the 2 variables s & t when I apply it to my particular example. I guess this could be that my functional is wrong, but I was kind of expecting the symmetry to fall out of the derivation, since ##\phi(s)## and ##\phi(t)## are really just the same function by a different name.
I agree up to this point. There is really no need for the integrals to be zero separately (although that would provide a solution). I am also not sure how to continue with this line of argumentation.
Ah, I see your point. Okay suppose we interchange the variables s and t in the second integral, and then exchange the order of integration (not sure if this is justified). Then we can combine the integrals and factor out the ##\eta(s)## such that
0=\int\int\left( \frac{\partial}{\partial \phi(s)}\left(L(s,t)+L(t,s)\right) - \frac{\partial}{\partial s}\frac{\partial}{\partial \dot{\phi}(s)}\left(L(s,t)+L(t,s)\right) \right)\eta(s)dsdt
And then the integrand would definitely equal 0, so
\frac{\partial}{\partial \phi(s)}\left(L(s,t)+L(t,s)\right) - \frac{\partial}{\partial s}\frac{\partial}{\partial \dot{\phi}(s)}\left(L(s,t)+L(t,s)\right)=0
(by L(s,t) I mean ##L\left(\phi(s),\phi(t),\dot{\phi}(s),\dot{\phi}(t)\right)##, and L(t,s) I mean ##L\left(\phi(t),\phi(s),\dot{\phi}(t),\dot{\phi}(s)\right)##, same Lagrangian, but with the positions of the ##\phi(s)## and ##\phi(t)##'s switched)
I do not see anything immediately wrong with doing that. On the other hand I have not thought about it much.
Related to Calculus of variations question
1. What is the calculus of variations?
The calculus of variations is a mathematical field that deals with finding the optimal path or function that minimizes or maximizes a given functional. It is used to solve problems in physics, economics, and engineering, among others.
2. What is a functional?
A functional is a mathematical function that maps a set of functions to a set of real numbers. In the calculus of variations, the functional represents a quantity that we want to optimize, such as distance, energy, or cost.
3. How is the calculus of variations different from traditional calculus?
Traditional calculus deals with finding the maximum or minimum of a function of one or more variables, while the calculus of variations deals with finding the maximum or minimum of a functional of a function. In other words, it is concerned with finding the optimal function rather than just a single value.
4. What are some real-world applications of the calculus of variations?
The calculus of variations has various applications, including finding the shortest path between two points, determining the optimal shape of a structure to withstand forces, minimizing the energy used in a system, and optimizing the trajectory of a rocket or satellite.
5. What are some techniques used to solve problems in the calculus of variations?
Some common techniques used in the calculus of variations include the Euler-Lagrange equation, the method of variations, and the principle of least action. These methods involve finding stationary points of the functional, which correspond to the optimal solution.
