Calculus project: volumes, rates, etc
In summary, the problem involves Houdini being trapped in a giant flask with his feet shackled to a block. Water is being pumped into the flask at a rate of 22pi. The goal is to calculate the height of the block so that the water reaches the top of Houdini's head in 10 minutes. By setting up the equation v=100pi(ln(h+1)) and solving for h, it is found that the block should be approximately 8 feet tall. Additionally, Houdini has derived an equation for the rate of change of the water level, dh/dt, as a function of h(t). The water level changes at a rate of 0.22(h+1)-1 when the
UWMpanther
Houdini is in a giant flask and he stands on a block where his feet are shackled and you need to calculate some vital information to help him out.
Cross section of flask = r(h)=10/(sqrt(h+1))
water is being pumped into the flask at 22pi
Takes Houdini 10 mins to escape
Ignore blocks volume and his volume
He's 6ft tall
1) You first task is to find out high the block should be so that the water reaches the top of his head at the 10 min mark. Express the water in the flask as a function of the height of the liquid above ground level. I calculated this to be approximately 2ft.
220pi=100pi(ln(h+1))
h≈8ft
2) Let h(t) be the height of the water above ground level at time t. In order to check the progress of his escape moment by moment, Houdini derived the equation for the rate of change dh/dt as a function of h(t) itself. Derive this equation. How fast is the water level changing when the flask first starts to fill? How fast is it changing when the water just reaches the top of Houdini's Head? Express h(t) as a function of time.
v=100pi(ln(h+1))
dv/dt=100pi((h'+1)/(h+1))
solve for h'? h'=.22(h+1) - 1
integrate this?
I stopped reading after "1) You first task is to find out high the block should be so that the water reaches the top". I suggest you write the problem correctly indicating what each variable mean (ex: what is h? and what does 22pi means?) and write grammatically correct sentences.
FAQ: Calculus project: volumes, rates, etc
1. What is the purpose of a calculus project on volumes, rates, etc?
The purpose of a calculus project on volumes, rates, etc is to apply the concepts and techniques learned in calculus to real-world problems and scenarios. This project allows students to see the practical applications of calculus in fields such as engineering, physics, economics, and more.
2. What are some examples of real-world problems that can be solved using calculus concepts of volumes and rates?
Some examples of real-world problems that can be solved using calculus concepts of volumes and rates include finding the volume of a water tank, determining the rate of change of a population, calculating the velocity of a falling object, and predicting the growth of a financial investment.
3. How do volumes and rates relate to each other in calculus?
Volumes and rates are closely related in calculus. Volumes can be thought of as the accumulation of rates over a specific time or interval. In other words, the volume of an object can be found by integrating the rate of change of that object over a given time period.
4. What are some common techniques used to solve calculus problems involving volumes and rates?
Some common techniques used to solve calculus problems involving volumes and rates include the Fundamental Theorem of Calculus, integration by substitution, and integration by parts. These techniques allow for the calculation of volumes and rates using various formulas and methods.
5. How can understanding calculus concepts of volumes and rates be beneficial in everyday life?
Understanding calculus concepts of volumes and rates can be beneficial in everyday life in many ways. It can help in making informed decisions related to finances, investments, and business growth. It also allows for a better understanding of changes and trends in various fields such as economics, physics, and engineering. Additionally, it can improve critical thinking and problem-solving skills.
