Calculus Related Rates Interesting Problem
In summary, the problem involves a leaking water balloon with a circumference that is decreasing at a rate of 1/8 cm per second. The task is to determine the volume of the balloon before it began to leak, given that it will be empty after five minutes.
Gregarious101
http://www.kent.k12.wa.us/pcpow/questions/calc/0401trickortreat/index.html
This is an old problem, and I have been able to solve one and two, I believe the answers are
1. pi cm/second
2. 50(pi) cm^3/second
3. This is the one I am not sure of. How can I solve this? Isn't there two many variables?
V=4/3(pi)r^3
dV/dt= 2(pi)r^2
dC/dt= (2(pi))*cube root(V/(4/3(pi)))*(1/(4/3(pi)))*(dV/dt)
I am getting lost at three, the rest are pretty easy, I think.
THANK YOU!
Welcome to PF!
Hi Gregarious101! Welcome to PF! :smile:
(have a pi: π and try using the X2 tag just above the Reply box :wink:)
3. The balloons are all full now and the kids are ready to go. A little boy named Billy grabs a water balloon but realizes the he’s already getting wet even though no balloon has been tossed. Billy looks down at his balloon.
OH NO! There is a small leak in his balloon. The circumference is decreasing at a rate of 1/8 cm per second.
If the balloon is empty after five minutes, what was the volume of the balloon before it began to leak (round to three decimal places)?
Just do it the other way …
The circumference is increasing at a rate of 1/8 cm per second: if it starts empty, what its it after five minutes?
FAQ: Calculus Related Rates Interesting Problem
What is a related rates problem in calculus?
A related rates problem in calculus involves finding the rate of change of one variable with respect to another variable, given their relationship. This typically involves using the chain rule to differentiate a function and setting up an equation with the known rates of change.
How do you solve a related rates problem in calculus?
To solve a related rates problem in calculus, you must first identify the variables involved and their relationship. Then, use the chain rule to differentiate the related functions and set up an equation with the known rates of change. Finally, solve for the unknown rate of change.
Can you give an example of a related rates problem in calculus?
One example of a related rates problem in calculus is a ladder sliding down a wall. The distance between the top of the ladder and the wall decreases at a constant rate, while the base of the ladder moves away from the wall at a constant rate. The goal is to find the rate at which the ladder is sliding down the wall.
What is the importance of understanding related rates in calculus?
Understanding related rates in calculus is important because it allows us to analyze real-world situations and determine how different variables are related and changing over time. This can be useful in various fields such as physics, engineering, and economics.
Are there any tips for solving related rates problems in calculus?
One helpful tip for solving related rates problems in calculus is to draw a diagram to help visualize the situation and identify the variables involved. It is also important to carefully read the problem and clearly define the given rates of change. Additionally, practice and familiarizing yourself with the different types of related rates problems can improve your problem-solving skills.
